benjamincq
Connecting to my HUB4 settings
Hi, I've been using my HUB 4 for the last 4 month with out and issue last week the wifi keep dropping in and out. I have done a full rest of my HUB and had new signals sent to my house. I have gone to to sign into my HUB 4 setting http://192.168.0.1 and I get greeted with welcome back to your virgin hub 3. dose anyone know how to make it connect to my hub 4? I have tried on my macbook over WiFi and tried on a windows laptop connected via an ethernet port.
carl_pearce
  • 4.73K
  • 403
  • 707
Superstar
Re: Connecting to my HUB4 settings
That address is where all your devices get their connection from, so it must be your HUB, regardless of what the login page states.
benjamincq
I cant log in on the HUB 3 login page I have tried the password at the bottom of the rooter and I have tired the password that I changed my HUB 4 to both passwords dont work.
-tony-
  • 16K
  • 1.26K
  • 3.77K
do another full reset - make sure you hold the button a good 30sec - dont guess time it and add a bit
after that log in again - use a lan cable if you can rather than wifi - the message should say hub4 - could it be someone near has a hub3 and you are logging onto that rather than your hub4 - cannot see how though
____________________
Tony
