Gforce5
Settling in
Message 1 of 10
Connecting home office
Hi I’m trying to set up a network in my garden office. My builder has run a cat5 cable out to it (from virgin 3 hub in my house) and when you plug that cable directly into a laptop it delivers the internet to it so fine so far.  However I then also have a switch from TP link that then connects a TP link WiFi router and also 3 hard wired internet ports. When I connect the cable to the TP link kit (as opposed to directly to the laptop)  it fails to deliver the internet.  Error message I get is there isn’t a valid IP configuration.  Been round the houses trying to sort it so anyone with ideas/advice that would be great. Cheers
gary_dexter
  • 30.24K
  • 1.87K
  • 4.02K
Message 2 of 10
Re: Connecting home office
CAT5 is limited to 100Mbps - are you sure it wasn't CAT5e or CAT6 he installed?
That aside, where is this switch and TP-Link router located? In the main house or the garden office?
You can't have 2 devices on the same network acting as routers.
Gforce5
Settling in
Message 3 of 10
Thanks for the reply. Yep he ran cat5e cable out, the network switch and WiFi router are in the garden office connected to the virgin hub in my house
gary_dexter
  • 30.24K
  • 1.87K
  • 4.02K
Message 4 of 10
What model is the Router?
If you need Wifi in there then you should use an access point really rather than a fully-fledged router.
Or at the very least put that Router into Bridge/AP mode.
Gforce5
Settling in
Message 5 of 10
Ah ok.. the device I have is TP link ac1750.  Cheers
gary_dexter
  • 30.24K
  • 1.87K
  • 4.02K
Message 6 of 10
You'll need to put it into AP/Bridge mode then.
Connection will look like this:
Hub---CAT5E to office---AC1750 (in AP/Bridge Mode)---TP-Link Switch---Devices
  • 2.86K
  • 215
  • 606
Trouble shooter
Message 7 of 10
@gary_dexter wrote:
<snip>
Personally I would do as below?
Hub---CAT5E to office---TP-Link Switch for ethernet devices---AC1750 (in AP/Bridge Mode) for WiFi Devices
But it should work either way.  The AC1750 should have a static IP address outside the range of the Hub DHCP scope.
Gforce5
Settling in
Message 8 of 10
Thank you. I’m just attempting to do that now and have reset the device.  It is asking me to set it up with the following options: 1. dynamic IP 2. Static IP  3. PPPoE 4. L2TP or 5. PPTP  can you advise please as assume it’s one of these that will set it up in the correct mode?  Cheers
gary_dexter
  • 30.24K
  • 1.87K
  • 4.02K
Message 9 of 10
You need to skip that part and set it to AP/Bridge mode in the main settings page.
  • 2.86K
  • 215
  • 606
Trouble shooter
Message 10 of 10
From the manual. You need to configure the AC1750 to Access Point Mode.
4. 4. Configure the Router in Access Point Mode
In this mode, your router connects to a wired or wireless router via an Ethernet cable
and extends the wireless coverage of your existing network. Advanced functions like
NAT, Parental Controls and QoS are not supported in this mode.
1. Connect the router’s Internet port to the existing router’s Ethernet port via an
Ethernet cable.
Chapter 4 Set Up Internet Connection
2. Visit http://tplinkwifi.net, and log in with your TP-Link ID or the password you set for
the router.
3. Go to Advanced > Operation Mode, select Access Point and click Save. Log in to the
router via http://tplinkwifi.net after the router reboots.
4. Go to Quick Setup or Settings > Wireless > Wireless Settings and set the SSIDs and
passwords for the wireless network.
Now, you can connect to the SSIDs and enjoy your existing network.
