Connecting broadband cables to the wall
Mcgr
How do I connect these two cables?
2 REPLIES 2
goslow
If you have a cable/plug trailing from the wall, you may need a coupler adapter to join two plugs together
https://www.diy.com/departments/f-type-screw-connector-female-socket-coupler-adapter-sat-coax-cable-...
Also available from the likes of Screwfix, Homebase, Toolstation etc.
Alternatively, call the pre-installation and delivery team on 0800 052 1734 explain the problem and request a tech visit to install a proper socket.
nodrogd
The coupler referred to in @goslow ‘s post may work, but if there are any further problems give Virgin Media Ireland a call on 01 245 8000. This forum is for the UK based company's residential customers, & the two operate as totally separate entities. The 0800 number is for the UK pre-install team.
VM 350BB 2xV6 & Landline. Freeview/Freesat HD, ASDA/Tesco PAYG Mobile. Cable customer since 1993
