Napier
Connecting Sony KD=55A1 Android TV to Hub 3.0 via wired LAN
Hello,
Android TV setup is looking for IP Address and Subnet Mask.  Where can I find this please?
Iain
  • 11.8K
  • 1.08K
  • 2.56K
griffin
Re: Connecting Sony KD=55A1 Android TV to Hub 3.0 via wired LAN
If you mean gateway IP address, then it should be 192.168.0.1 (assuming the Hub is in router mode) and the subnet mask should be 255.255.255..0
  • 4.89K
  • 341
  • 831
Roger_Gooner
Superstar
The hub's DHCP server will assign an IP address for the TV when you connect with an Ethernet cable. It should be plug and play.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
