on 28-07-2023 12:33
Hi there,
I am trying to get my VMC App to work so I can see if my Pods are working properly and in the best locations.
I have followed all of the online suggestions. My Hub 4 is in Modem Mode, I am sat next to it 1metre away, cleared the cache on my phone, uninstalled and reinstalled the app, rebooted the router and it still cannot find or connect to the hub.
Any help please?
James
28-07-2023 12:42 - edited 28-07-2023 12:43
The app doesn't work when the HUB is in modem mode, unless you meant router mode considering you have pods?
on 28-07-2023 14:36
Ah okay thanks, I thought I read online it had to be in modem mode.
Will give it a try that may explain why my Pods don't appear to be working either 😞
28-07-2023 14:45 - edited 28-07-2023 14:45
In modem mode only one wired device would work. This mode is used for when you want to use your own third party mesh/router.
No other wired or wireless devices will work, including pods.
on 29-07-2023 13:07
Hi JChilds85,
Thanks for posting and welcome to our community 🙂
How have you got on with this since carl_pearce suggestion?
Alex_Rm
on 29-07-2023 16:12
Hi there, so I've double checked this and I was mistaken, my hub is in Router mode as it is supposed to be
on 30-07-2023 08:38
yesterday
Hi there,
so I've double checked this and I was mistaken, my hub is in Router mode as it is supposed to be. Still cannot get the app to detect my hub
on 31-07-2023 11:43
Thank you for that information.
Do you have any other devices that have the VMC app on?
^Martin
