@DJ_Shadow1966 wrote:
Hello
The ipV6 is a red herring as currently there is no ipV6 on any virginmedia connections, that has nothing to do with the connection to the fire alarm.
Regards Mike
The device will work over a v4 network for sending notifications etc.. but for initial setup - either connecting a new protect device with an existing or connecting a single device to the nest app - the comms all happens over v6, with no support for 4.
it doesn't require internet connectivity over v6, it does all of that over v4, but it needs a v6 (ULA is fine) address to get up and running..
doesn't matter that VM doesn't support v6 in their network, if the gateway device supports it, you can get them working fine.
