Hi @Chopper1885
Have you changed anything on your hub?
The pods only work under certain conditions.
Keep your Hub in Router Mode - Do not put the Hub into Modem Mode, as this disables the Wi-Fi and your Pods are connecting to your Hub via Wi-Fi. Likewise, if you use a third-party router it will not work because the Pods are designed to specifically connect directly with VM's Hubs only.
Do not split the SSID – If the SSID is split then the hub treats the two bands as two different standalone networks (the same as picking up your neighbours Wi-Fi when you search for a network). The Smart Wi-Fi cannot move a device between different networks.
Do not disable either bands – If both bands (2.4GHz and 5Ghz) are not switched on then the software cannot move the device for optimisation, which essentially disables the Smart Wi-Fi.
You should also ensure that Chanel Optimisation is enabled in your hub settings.
DaveI don't work for Virgin Media.
The do's and don'ts. Keep the community welcoming for all.
Follow the house rules The Service you do for others is the rent you pay for your room here on Earth - Muhammad AliLove, love and love, forever - Pele
