MrG0410
Configuration for the Hub 3 m600 speed issue
Does anyone know what the correct configuration for the Hub 3 should be.I am an Ultimate Oomph customer. I recently installed the 3 intelligent WiFi pods and received a email a few weeks ago advising that "We’ve been busy upgrading our Intelligent WiFi tech to give you our most reliable WiFi experience with your Hub 3.The good news is this new-and-improved WiFi is now live in your home, at no extra cost." How do I find out if this upgrade has been made or could someone look at my configuration details below. Thanks
Cable Modem Status
Item Status Comments
Acquired Downstream Channel (Hz) 171000000 Locked
Ranged Upstream Channel (Hz) 32600000 Locked
Provisioning State Online
1 171000000 7.1 38 256 qam 5
2 139000000 8.1 38 256 qam 1
3 147000000 8 38 256 qam 2
4 155000000 7.5 38 256 qam 3
5 163000000 7.3 40 256 qam 4
6 179000000 7 40 256 qam 6
7 187000000 7.3 38 256 qam 7
8 195000000 7.1 40 256 qam 8
9 203000000 7 40 256 qam 9
10 211000000 6.5 38 256 qam 10
11 219000000 6 40 256 qam 11
12 227000000 5.8 38 256 qam 12
13 235000000 5.5 38 256 qam 13
14 243000000 5.6 40 256 qam 14
15 251000000 6.1 40 256 qam 15
16 259000000 5.8 40 256 qam 16
17 267000000 6.4 40 256 qam 17
18 275000000 6.5 40 256 qam 18
19 283000000 6.8 40 256 qam 19
20 291000000 6.6 40 256 qam 20
21 299000000 6.6 40 256 qam 21
22 307000000 6.5 40 256 qam 22
23 315000000 6.5 40 256 qam 23
24 323000000 6.5 40 256 qam 24
1 Locked 38.9 59 0
2 Locked 38.6 46 0
3 Locked 38.9 24 0
4 Locked 38.9 58 0
5 Locked 40.3 51 0
6 Locked 40.3 47 0
7 Locked 38.9 55 0
8 Locked 40.9 46 0
9 Locked 40.9 34 0
10 Locked 38.9 47 0
11 Locked 40.3 112 0
12 Locked 38.9 173 0
13 Locked 38.6 201 0
14 Locked 40.3 189 0
15 Locked 40.9 197 0
16 Locked 40.3 416 0
17 Locked 40.3 420 0
18 Locked 40.9 349 0
19 Locked 40.9 363 0
20 Locked 40.3 635 0
21 Locked 40.3 939 0
22 Locked 40.3 857 0
23 Locked 40.3 1051 0
24 Locked 40.3 1087 0
Refresh data
1 32600000 41.8 5120 64 qam 5
1 ATDMA 0 0 0 0
Refresh data
General Configuration
Network access Allowed
Maximum Number of CPEs 1
Baseline Privacy Enabled
DOCSIS Mode Docsis30
Config file fg87dsfd;kfoA,.iyewrkldJKDHSU
SFID 7246
Max Traffic Rate 690000278
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 14238
Max Traffic Rate 44000278
Min Traffic Rate 0
Max Concatenated Burst 42600
Scheduling Type BestEffort
Refresh data
13/04/2021 21:56:58 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=xxxxxxxx;CMTS-MAC=xxxxxxxxxxxCM-QOS=1.1;CM-VER=3.0;
13/04/2021 21:56:48 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=xxxxxxxxxxCMTS-MAC=xxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
13/04/2021 21:56:28 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=xxxxxxxxxxxCMTS-MAC=xxxxxxxxxxxxxCM-QOS=1.1;CM-VER=3.0;
13/04/2021 21:56:28 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
13/04/2021 21:56:8 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=xxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
13/04/2021 21:56:8 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=xxxxxxxxxxCMTS-MAC=xxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
13/04/2021 21:55:38 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=xxxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxxxCM-QOS=1.1;CM-VER=3.0;
13/04/2021 21:55:28 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=xxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
13/04/2021 21:55:8 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=xxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
  • 15.93K
  • 687
  • 1.56K
Re: Configuration for the Hub 3 m600 speed issue
Seems you have one upstream so that needs to be looked at.
MrG0410
Thanks for the reply.
Not being technical with such things, what would you suggest I need to do/ what should I do, about the upstream?
  • 2.91K
  • 220
  • 622
Trouble shooter
Reboot your Hub and check again.  If it still only negotiates one US channel then an engineer will be required to sort it out.
As for the Wifi, what firmware version are you on at present?
