heatherbryson77
Message 1 of 12
Complaint - signal issues and support
Can anyone advise how I can raise a complaint? New customer to Virgin and really unhappy about the signal issues and lack of support.
Many thanks!
Andrew-G
  • 6.17K
  • 1.08K
  • 2.62K
Message 2 of 12
Re: Complaint - signal issues and support
Don't waste your time on the phone, you probably know how good the telephony is.  There's an online complaints form that you can use, but you need to log into "My Virgin Media" to find it.
lotharmat
  • 937
  • 69
  • 141
Well-informed
Message 3 of 12
You can raise it here.
In the mean time - People on here will be glad to help sort any issues out.
Can you post your Hub status and logs?
Someone should be spot if there is a problem
Navigate to http://192.168.0.1 (or http://192.168.100.1 - if in modem mode)
Don't log in!
Click on 'router status'
Copy/paste the data from each of the tabs. The forum software will remove the MAC addresses for you (you may need to click the 'post' button again).
Also, set up a 'Broadband Quality Monitor'. This will monitor the state of your connection and record any network dropouts etc - You can do this at ThinkBroadband (https://www.thinkbroadband.com/broadband/monitoring/quality)
heatherbryson77
Message 4 of 12
Thank you 🙂
LSW1927
  • 7
Message 5 of 12
Good luck - I’m in the same boat. Telephone support is useless- they will make promises that are never fulfilled (eg an engineer will call within 4 hours). The diagnostics they’re running show no fault and no area outages but the app is telling me there’s an outage in my area! No broadband for 3 days now!
heatherbryson77
Message 6 of 12
Soooooooo frustrating.......
g0akc
  • 891
  • 83
  • 171
Well-informed
Message 7 of 12
Raise a complaint online, but the form, and locations of it, seem to keep changing.  The latest link seems to be this;
https://www.virginmedia.com/shop/contactus/make-a-complaint
You will need to login.
However, it takes weeks for any response, and often the complaints are closed without any real action.
You then need to look at raising a case with CISAS.  That will also take ages (months) to get anything done.  You may at least get some compensation from it, depending what it is you want.
I know a bit about Wi-Fi, Telecoms, and TV as I used to do it for a living but I'm not perfect so don't beat me up... If you make things you make mistakes!
lotharmat
  • 937
  • 69
  • 141
Well-informed
Message 8 of 12
I raised 2 complaints a while back (via the web) - they were dealt with within 3 days each time!
The time does seem to vary quite a bit!
heatherbryson77
Message 9 of 12
g0akc
  • 891
  • 83
  • 171
Well-informed
Message 10 of 12
You were lucky
I’ve just had them ‘close’ a CISAS complaint on the basis that a separate complaint had already been settled - without tackling the new issue at all.
Now I’ve got to ring and start over with CEDR.
It can be exasperating!
