Colour of base light on Hub 3.0
I'm sure this is probably a non-issue, but the manual that came with my new Hub 3.0 states that the base light should be white. It was when I first set up and checked it out with a direct connection to my PC.
Then I set the hub up as 'modem only' and the base light changed to red (actually an attractive pink!). With my old Netgear router connected my home network (hard wired and WiFi) seem to work perfectly and the hub is far from hot.
So, is the red light when in 'modem' mode OK?
  • 1.85K
  • 264
  • 413
Super solver
Re: Colour of base light on Hub 3.0
Hello
That is correct the base light when in modem only mode is Pinkish / Magenta like. Long time modem only mode user.
Regards Mike
I dont work for VirginMedia all opinions are my own.
39 years in IT.
