chiviv
Coax cable replacement
How do I book an appointment to have internal cables shorten/relocated and old outside box (white)  replaced?
japitts
  • 10.6K
  • 1.49K
  • 2.14K
Re: Coax cable replacement
In normal times, you'd call VM and arrange a non-fault engineer visit at £99.
In the current climate, these visits are not being arranged - home engineering visits are being limited to single-room installs and fault-fixes only. Your request is neither, so at the moment this can't be done.
You can check for updates on this policy at https://www.virginmedia.com/help/coronavirus-update
Ayisha_B
  • 758
  • 21
  • 73
Hi @chiviv,
Welcome to our Community Forums and thank you for your post.
Unfortunately, we are currently unable to offer non-essential engineering visits. This is to protect our customers and our staff. We will be happy to take a look into this once things have eased.
Thank you
Ayisha_B
