Clover PDQ problems
bosstoad
Has anyone experienced problems with using Clover PDQ equipment with Virgin Broadband and found solutions please?
18 REPLIES 18
jpeg1
When you are talking to Clover, it would be as well to let them know if they don't already, that Virgin Business and Virgin Media their residential service use different modem/routers, and this might just have an influence on the problem.
As this is the Virgin Media forum, you won't get any official support here for business uses.
- jpeg1
My name is not Alessandro. That is just a tag Virginmedia foisted on me.
Thanks for your note, is there a separate User Forum for the Business product please? Incidentally I am also a personal customer of Virgin Media.
jpeg1
I don't think there is, no.
- jpeg1
Work in IT for Retail and Funeral.
I believe it has to do with the way the Hitron router makes a connection to VM over a GRE tunnel, and not allowing a proper modem only mode without having a group of static IPs... but without testing I cant say for sure.
Hi @bosstoad
I'm afraid there isn't a business forum.
Link to the VM Business contact details
https://www.virginmediabusiness.co.uk/help-and-advice/get-in-touch/contact-us/
Dave
The do's and don'ts.
I have now received a response from Virgin Business pointing me to Port Forwarding on the Hitron Router..... Clover use Port 443.
Not familiar yet with this but will investigate. This reply to give you an update in case you are familiar with the technique.
I upgraded to 1 gig and the router was changed to a Hitron Chita and the problem disappeared.
Hi bosstoad, thanks for the message.
I am glad to hear that the router has resolved things for you.
Please let us know if you need anything further.
Kind regards, Chris.
