I’m setting a device to a static IP address and every time I click on apply changes in the DHCP settings the Wi-Fi switches off.
I had it set on my previous router. Engineer changed my router yesterday to a Hub 3.0. The device has the IP in its settings, I’ve been using it for 2 years.
I logged into my router, got the IP the device is on, set it to the IP I want (not in use by anything else) and set the rule. All ok until I click apply changes, that’s when the Wi-Fi switches off. I’ve tried it on 5g & 2.4g, both switch off. Does anyone have any suggestions?
I will also be using port forwarding with this static IP.
