judita041
Message 1 of 7
Cant scan for wifi after factory reset
Hey,
I'm having issues with seeing my hub 3 name when scan for wifi.
I have factory reset the hub and it now has a static white light (no issues) yet I cannot see the name of the hub under the wifi options to connect.
Any thoughts how to resolve this?
Appreciate every help!
conman33158
  • 726
  • 66
  • 95
Superfast
Message 2 of 7
Re: Cant scan for wifi after factory reset
Type 192.168.0.1 into your URL bar on your browser and enter the hub wireless settings and make sure the wifi is enabled.
judita041
Message 3 of 7
I've tried this but getting 'this website cant be reached' error?
conman33158
  • 726
  • 66
  • 95
Superfast
Message 4 of 7
Try another factory reset. Hold in the pinhole at the rear of the router for at least 50 seconds and then release (the lights will flash while holding in the pinhole reset button after about 10-15 seconds) then allow 5 minutes for the router to reboot and re-sync the connection.
judita041
Message 5 of 7
It's back on working after second factory reset, no need to type in the link either.
However, having issues with Ethernet, the troubleshooting on my laptop says it doesn't have a valid IP configuration.
Would you be able to advise on this also?
conman33158
  • 726
  • 66
  • 95
Superfast
Message 6 of 7
Could be a faulty cable, try a different Cat5e or better cable and see if this resolves your issue 🙂
judita041
Message 7 of 7
thanks alot for your help! 😊
