on 27-09-2023 08:50
Paused 3 things last night but unable to resume connection on Linux pc. Thought this was fixed for hub 5. How do I bypass it to get it working.
on 27-09-2023 10:06
Easiest way is a pin hole reset of the hub.
on 27-09-2023 10:19
You can also use an un-paused device, login to the Hub's menus and then remove the MAC Address Filtering.entries or better disable MAC Address Filtering once and for all.
