@Ealther wrote:
I am not getting ping from the 4 ethernet port on the back of the router.
Problem is that the HUB is in bridge mode so i cannot troubleshoot.
I tried different cables, different laptop, no luck, so I suspect it is the router either hardwarz or config
Do you mean “modem mode”?
if so, only one Ethernet port will be working, the one that supplies a connection to your router.
you can still access the hub on 192.168.100.1 when connected to your router though...
