Can't log into my Hub 3.0 settings
Hello,
Since the installation of my Hub 3.0, I have been having trouble signing into my Hub 3.0 settings @ http://192.168.0.1/.
I have been using the default settings password provided on the hub itself (NOT the WiFi password) and I have hard reset the router itself at least 10 times now (including waiting at different intervals before turning it on again) to no avail.
The error message I get is "The password you entered is incorrect." even though it has not been changed/has been reset.
  • 4.37K
  • 743
  • 1.77K
Re: Can't log into my Hub 3.0 settings
Nothing more you can try.  I have flagged your post for the forum staff, so should get a response today on next steps.
  • 2.8K
  • 160
  • 347
Hi Einjiru, thanks for your post.
Sorry to hear about the problem you've had accessing your hub's settings. Can I just check that you've tried pushing in the reset button for a timed 60 seconds?
If you have without success then please get back to me via PM so we can assist further.
Tom
