Can’t connect wifi
Genk
Hi, l just can’t connect to the Wi-Fi as I went back today. This is the first time I came across the problem. The system kept saying that “we can’t find your hub” whenever I tried to install it. I also tried to unplug it but it still failed.
1 ACCEPTED SOLUTION
Accepted Solutions
Genk
Hi, it works now, thanks all
1 REPLY 1
Genk
