Morning
Really odd problem - I really appreciate any advice.
The Problem
192.168.01 is coming up unreachable even when connected to Hitron via ethernet cable.
When I look at network properties it is coming up as with the name of the BT Whole Home Discs - EVEN when they are physically disconnected from the Hitron.
Are the two things related ? If so what I can I do ? if not what I should
The Setup
Virgin Business 4 Port - Hitron CGNV4-FX4 ( wifi switched off)
4 x old school BT Whole Whole Wi-fi - one plugged straight into Mr Hitron
Steps taken so Far
I've done a factory reset - the result was a for a couple seconds I could access 192.168.01 but then it disappeared
Checked that the network is private rather the public on Network setting - no effect.
