I migrated over to 1Gb from 300Mb a week ago, and all was looking rosy until today. Since midnight today I've not been able to connect to Webex or any of their servers or sites. This is a massive issue for me as Webex tools are essential for my work. All other sites I use seem fine, just webex.
If I connect a VPN (1.1.1.1 or my work VPN) I can connect no problem, but just using VM without the VPN it seems there is a routing issue.
An example of ping and traceroute when it doesn't work here:
MacBookPro-13in ~ % ping mycwt.webex.com
PING global-nebulaij.webex.com (66.114.168.203): 56 data bytes
Request timeout for icmp_seq 0
Request timeout for icmp_seq 1
Request timeout for icmp_seq 2
Request timeout for icmp_seq 3
^C
--- global-nebulaij.webex.com ping statistics ---
5 packets transmitted, 0 packets received, 100.0% packet loss
MacBookPro-13in ~ % traceroute mycwt.webex.com
traceroute to global-nebulaij.webex.com (66.114.168.203), 64 hops max, 52 byte packets
1 gateway (192.168. 1.1) 1.459 ms 3.256 ms 1.122 ms
2 * * *
3 haye-core-2a-xe-122-0.network.virginmedia.net (80.3.178.173) 11.493 ms 12.783 ms 9.739 ms
4 * * *
5 m686-mp2.cvx1-b.lis.dial.ntli.net (62.254.42.174) 18.872 ms 13.714 ms 13.746 ms
6 * * *
7 us-nyc01b-rd2-ae-9-0.aorta.net (84.116.140.170) 90.806 ms 88.604 ms 84.132 ms
8 us-was03a-ri1-ae-10-0.aorta.net (84.116.130.174) 88.899 ms 87.876 ms 88.883 ms
9 4.68.39.141 (4.68.39.141) 89.124 ms 115.996 ms 90.525 ms
10 * * *
11 4.14.99.10 (4.14.99.10) 94.228 ms 90.513 ms 89.587 ms
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
and when it does work, via a VPN:
64 bytes from 66.114.168.203: icmp_seq=0 ttl=239 time=149.615 ms
64 bytes from 66.114.168.203: icmp_seq=1 ttl=239 time=148.722 ms
64 bytes from 66.114.168.203: icmp_seq=2 ttl=239 time=150.739 ms
64 bytes from 66.114.168.203: icmp_seq=3 ttl=239 time=147.654 ms
64 bytes from 66.114.168.203: icmp_seq=4 ttl=239 time=148.203 ms
^C
5 packets transmitted, 5 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 147.654/148.987/150.739/1.089 ms
1 * * *
2 5.253.114.17 (5.253.114.17) 13.973 ms 12.118 ms 10.196 ms
3 * * *
4 xe-0-3-1-0.a02.londen12.uk.ce.gin.ntt.net (192.80.16.82) 20.506 ms 16.765 ms 12.322 ms
5 ldn-b1-link.telia.net (62.115.154.42) 13.454 ms 12.795 ms 13.606 ms
6 ldn-bb4-link.ip.twelve99.net (62.115.122.180) 82.398 ms 85.493 ms
ldn-bb1-link.ip.twelve99.net (62.115.120.74) 84.312 ms
7 * * *
8 nyk-b5-link.ip.twelve99.net (80.91.254.14) 89.786 ms 93.037 ms
nyk-b5-link.ip.twelve99.net (62.115.115.1) 84.874 ms
9 cisco-ic-346961-nyk-b5.c.telia.net (62.115.177.223) 85.260 ms 87.457 ms 87.851 ms
10 * * *
11 jfk10-wxbb-crt01-bu60.webex.com (64.68.116.44) 80.104 ms 87.430 ms 83.983 ms
12 jfk10-wxbb-crt02-bu10.webex.com (64.68.118.33) 82.610 ms 87.307 ms 85.231 ms
13 ord10-wxbb-crt02-te0-5-0-2.webex.com (64.68.117.250) 104.766 ms 108.655 ms 103.976 ms
14 ord10-wxbb-crt01-bu10.webex.com (64.68.117.253) 102.576 ms 108.962 ms 104.231 ms
15 sjc02-wxbb-crt01-bu101.webex.com (64.68.117.62) 152.412 ms 148.702 ms 147.776 ms
16 sjc02-wxbb-pe01-bu11.webex.com (64.68.117.97) 149.132 ms 149.261 ms 151.304 ms
17 sjc02-wxp00-gw02-po512-100.webex.com (209.197.223.163) 150.538 ms
sjc02-wxp00-gw02-po522-100.webex.com (209.197.223.167) 148.552 ms
sjc02-wxp00-gw01-po521-100.webex.com (209.197.223.165) 156.905 ms
18 * * *
It does feel a little bit like this thread which didn't get solved. Any core network folks from Virgin want to comment on it? Routing issues leaving Level 3 networks in the US?
Thanks loads.
