treacle
Message 1 of 1
Can't connect to Webex and any of their sites
I migrated over to 1Gb from 300Mb a week ago, and all was looking rosy until today.  Since midnight today I've not been able to connect to Webex or any of their servers or sites.  This is a massive issue for me as Webex tools are essential for my work.  All other sites I use seem fine, just webex.
If I connect a VPN (1.1.1.1 or my work VPN) I can connect no problem, but just using VM without the VPN it seems there is a routing issue.
An example of ping and traceroute when it doesn't work here:
MacBookPro-13in ~ % ping mycwt.webex.com
PING global-nebulaij.webex.com (66.114.168.203): 56 data bytes
Request timeout for icmp_seq 0
Request timeout for icmp_seq 1
Request timeout for icmp_seq 2
Request timeout for icmp_seq 3
^C
--- global-nebulaij.webex.com ping statistics ---
5 packets transmitted, 0 packets received, 100.0% packet loss
MacBookPro-13in ~ % traceroute mycwt.webex.com
traceroute to global-nebulaij.webex.com (66.114.168.203), 64 hops max, 52 byte packets
 1  gateway (192.168.	1.1)  1.459 ms  3.256 ms  1.122 ms
 2  * * *
 3  haye-core-2a-xe-122-0.network.virginmedia.net (80.3.178.173)  11.493 ms  12.783 ms  9.739 ms
 4  * * *
 5  m686-mp2.cvx1-b.lis.dial.ntli.net (62.254.42.174)  18.872 ms  13.714 ms  13.746 ms
 6  * * *
 7  us-nyc01b-rd2-ae-9-0.aorta.net (84.116.140.170)  90.806 ms  88.604 ms  84.132 ms
 8  us-was03a-ri1-ae-10-0.aorta.net (84.116.130.174)  88.899 ms  87.876 ms  88.883 ms
 9  4.68.39.141 (4.68.39.141)  89.124 ms  115.996 ms  90.525 ms
10  * * *
11  4.14.99.10 (4.14.99.10)  94.228 ms  90.513 ms  89.587 ms
12  * * *
13  * * *
14  * * *
15  * * *
16  * * *
17  * * *
18  * * *
and when it does work, via a VPN:
64 bytes from 66.114.168.203: icmp_seq=0 ttl=239 time=149.615 ms
64 bytes from 66.114.168.203: icmp_seq=1 ttl=239 time=148.722 ms
64 bytes from 66.114.168.203: icmp_seq=2 ttl=239 time=150.739 ms
64 bytes from 66.114.168.203: icmp_seq=3 ttl=239 time=147.654 ms
64 bytes from 66.114.168.203: icmp_seq=4 ttl=239 time=148.203 ms
^C
5 packets transmitted, 5 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 147.654/148.987/150.739/1.089 ms
 1  * * *
 2  5.253.114.17 (5.253.114.17)  13.973 ms  12.118 ms  10.196 ms
 3  * * *
 4  xe-0-3-1-0.a02.londen12.uk.ce.gin.ntt.net (192.80.16.82)  20.506 ms  16.765 ms  12.322 ms
 5  ldn-b1-link.telia.net (62.115.154.42)  13.454 ms  12.795 ms  13.606 ms
 6  ldn-bb4-link.ip.twelve99.net (62.115.122.180)  82.398 ms  85.493 ms
    ldn-bb1-link.ip.twelve99.net (62.115.120.74)  84.312 ms
 7  * * *
 8  nyk-b5-link.ip.twelve99.net (80.91.254.14)  89.786 ms  93.037 ms
    nyk-b5-link.ip.twelve99.net (62.115.115.1)  84.874 ms
 9  cisco-ic-346961-nyk-b5.c.telia.net (62.115.177.223)  85.260 ms  87.457 ms  87.851 ms
10  * * *
11  jfk10-wxbb-crt01-bu60.webex.com (64.68.116.44)  80.104 ms  87.430 ms  83.983 ms
12  jfk10-wxbb-crt02-bu10.webex.com (64.68.118.33)  82.610 ms  87.307 ms  85.231 ms
13  ord10-wxbb-crt02-te0-5-0-2.webex.com (64.68.117.250)  104.766 ms  108.655 ms  103.976 ms
14  ord10-wxbb-crt01-bu10.webex.com (64.68.117.253)  102.576 ms  108.962 ms  104.231 ms
15  sjc02-wxbb-crt01-bu101.webex.com (64.68.117.62)  152.412 ms  148.702 ms  147.776 ms
16  sjc02-wxbb-pe01-bu11.webex.com (64.68.117.97)  149.132 ms  149.261 ms  151.304 ms
17  sjc02-wxp00-gw02-po512-100.webex.com (209.197.223.163)  150.538 ms
    sjc02-wxp00-gw02-po522-100.webex.com (209.197.223.167)  148.552 ms
    sjc02-wxp00-gw01-po521-100.webex.com (209.197.223.165)  156.905 ms
18  * * *
It does feel a little bit like this thread which didn't get solved.  Any core network folks from Virgin want to comment on it? Routing issues leaving Level 3 networks in the US?
Thanks loads.
