ArchieArcher
  • 14
Message 1 of 18
Can't connect smart security to 2.4GHz on Hub 4
I have a smart security device that only connects to 2.4GHz. I have accessed my Hub 4 and changed the name and password for the 2.4GHz channel. I can successfully connect to this channel on my iPhone and PS4 but I can't connect to it with my smart home security base station. I've tried switching off the 5 GHz channel but that didn't help. I've tried switching everything on and off again. Please help.
  • 22.44K
  • 2.4K
  • 4K
Message 2 of 18
Re: Can't connect smart security to 2.4GHz on Hub 4
Does the security base station need resetting to factory and then setting up again for your new ssid/password ?
  • 15.91K
  • 687
  • 1.56K
Message 3 of 18
The hub can sometimes not work with given devices so you may have to get your own wireless router with 1Gb ports and use the hub in modem mode.
ArchieArcher
  • 14
Message 4 of 18
The SimpliSafe hub was brand new so I'd assume it was set to factory settings, John.
I've tried restarting and disconnecting from power. I reset the hub as well.
ArchieArcher
  • 14
Message 5 of 18
So, I'd connect the router to the VM hub 4, then connect my home security to the router?
Z92
  • 2.26K
  • 187
  • 350
Problem sorter
Message 6 of 18
Yes just use the virgin box as a coax to ethernet converter. It's not very good at anything else.
Simplisafe depends on good WiFi so get a good WiFi router and preferably use battery backup for all 3 boxes.
ArchieArcher
  • 14
Message 7 of 18
Any suggestions for a good wifi router?
  • 22.44K
  • 2.4K
  • 4K
Message 8 of 18
Bit like asking "what's a good car"?
Depends... what features do you want, whats your location's layout and construction, what's your budget?
Z92
  • 2.26K
  • 187
  • 350
Problem sorter
Message 9 of 18
Unifi stuff is good but you might prefer something a bit more on the consumer level like Asus or net gear. That said there dream machine is supposed to be easy to setup but it is £380...
What's your budget? Is one WiFi good enough or are you looking for into a mesh solution?
ArchieArcher
  • 14
Message 10 of 18
Well, we have six adults living and working from home. Quite often all six connecting with laptops and a couple of PS4s too.
TBH, we never had much in the way of problems with the Hub 4.
