on 29-12-2023 12:27
Since I’ve had the hub 5 installed my WiFi pod isn’t connecting. I’ve read a few posts on here but can’t fathom it out. Seems to be that I need someone at virgin to connect the pod to the hub? Any help is appreciated, thanks in advance
on 29-12-2023 14:53
First, try the equipment activation number on - 0800 953 9500 (follow options) and check with them. You will need the Model numbers, serial numbers/MAC addresses off the barcode stickers of ALL pieces of kit and also your account number
