forumarchive,nothingtosee,
Laurance
  • 57
Can neighbour's wifi affect my wifi?
Hi I have a Hub 3.0 which gives me home wifi. The Hub is in the centre of the house where it has been for many years.
Recently i have started to loose wifi contact with my Hub dropping off wifi. Is it possible that my next door neighbour who runs a business from home that his "business" wifi signal could be affecting my wifi? When I check for available wifi networks his always appears first with max strength, and yet mine shows less than max strength?
If his wifi network is responsible for my drop-offs can anyone suggest a good solution to prevent this from happening?
Many thanks in advance
Laurance
spgray
  • 2.39K
  • 139
  • 338
Problem sorter
Re: Can neighbour's wifi affect my wifi?
them being a "business" has nothing to do with it, but any neighbouring wifi network can affect everyone elses.
try changing the wifi channel yours uses to one that is less conjested.
My Broadband Ping - spgray
Laurance
  • 57
Many thanks SPGRAY, sorry to be a "no-nothing", but how do I go about changing wifi channels, and if I do so will it have any adverse effect on all my devices at home?
Many thanks again,
Laurance
spgray
  • 2.39K
  • 139
  • 338
Problem sorter
https://www.virginmedia.com/help/virgin-media-changing-your-hubs-wireless-channel
