Cable extension
Vidhi
We're doing some redecorating and would like to move our Hub 3 to a different area of the room. I need an extension to the coaxial cable to do this, and will be running it through the ceiling and down the wall to its new location.
I need large extension cable.
Pls help.thank you
3 REPLIES 3
Tom_W1
Hi @Vidhi thanks for your post here in the Community - welcome!
No problem, ideally we can look to send this out but if not feasible, it would need a technician callout to help relocate the Hub which would be £25 non-fault callout charge.
However, please allow me to send you a PM so I can look into things further for you.
Kindly expect the PM to arrive shortly and respond directly when you can!
Many thanks
Tom_W
Yes I m allowing you. I will pay £25 but please fix this asap.
Hi @Vidhi thanks for your reply.
I have sent you a PM so kindly reply to the question I have asked there - if you look at the envelope icon on your screen you should be able to see the message there.
Many thanks
Tom_W
