Just joined
Cable Length
Hi all,
Been a Virgin Customer for a few years now, but only recently signed up for the forum!
Im looking for a bit of advice, when I've had my installation, the router is placed pretty much a metre, if not shorter, away from the external wall socket. This means that the cabling which runs from one to another is far, far too long. Is there anyway I can order a shorter cabling, as the excess looks so untidy.
Same for the AC Power plugs for both the Hub and the TV box, are their short cabling versions of those available?
Many thanks!
  • 25.21K
  • 1.45K
  • 3.21K
Re: Cable Length
You can ask them to send shorter cabling. Or can you put it under the flooring?
