Message 1 of 7
Cable Haunt issue
I just heard about the Cable Haunt vulnerability issue with most cable modems. Is anyone at virgin media looking into this vulnerability?
BR
  • 61
  • 5
Dialled in
Message 2 of 7
Re: Cable Haunt issue
IIRC, the exploit impacts routers with Broadcom CPU's.
I know the SH3 and SH4 are intel powered, how about the older routers?
  • 14.27K
  • 591
  • 1.37K
Message 3 of 7
It would seem VM for the super hub 1 has blocked off port 8080 to 192.168.100.1 on the hub to not have that vulnerability.
You can have a firewall to only allow only port 80 and ICMP to 192.168.100.1 to not have this problem.
the attack is from your LAN by a browser by your end not remotely by WAN side
  • 12
Message 4 of 7
This isn't solved. This a mitigation that most of the customers will struggle to implement.
This issue has been known about by ISPs since MAY 2019, the fix has been published a requires a firmware which can only be done by the ISP. Which I suspect there will be reluctance as this causes an outage for ~1hr. But if the bad guys get in first they can upload their own firmware which will lock out the ISP..  What are you planning to do about this?
Exploit code is already available if you search for it..  I don't think this can be ignored.
https://cablehaunt.com
  • 2.48K
  • 156
  • 643
Problem sorter
Message 5 of 7
Do we know which (if any) VM routers are affected? Hub 3 and Hub 4 definitely aren't, neither is the SH2ac which was a Puma 5. Not sure about the original SH2 and SH1.
  • 30.3K
  • 1.51K
  • 5.26K
Message 6 of 7
the SH1 and 2 are EOL so they will not get patched even if they are effected.
  • 7.42K
  • 254
  • 1.77K
Community Lead
Community Lead
Message 7 of 7
Hi everyone,
As you’d expect, we regularly test our equipment in light of new security developments. Following further investigation we can confirm that we are not exposed to these issues on our product portfolio.
Kev
