  • 5
Message 1 of 10
CGNV4-BIZ port forwarding problem
Hi all,
We have a business broadband account with Virgin, with a CGNV4-BIZ router.  I'm trying to forward port 8443 to an internal server with the IP 192.168.0.17.  I logged onto the router, clicked on "Basic" - "Port Forwarding" and forwarded port 8443-8443 from public, 8443-8443 to private, protocol TCP/UDP, internal IP address 192.168.0.17, however when I do an external port check to our public IP with the port number 8443, it shows up as "closed".  I checked the server, and it seem to say port 8443 is open and listening. I can access port 8443 on an internal computer.  How can I make port forwarding work for this please?
Many thanks for your time in advance!
  • 14.81K
  • 622
  • 1.43K
Message 2 of 10
Re: CGNV4-BIZ port forwarding problem
Put it in modem mode get your own router
https://www.virginmediabusiness.co.uk/help-and-advice/products-and-services/hitron-router-guide/dyna...
  • 5
Message 3 of 10
Not an option at the moment, I'm afraid. Is there another way to do this please?
Cheers
  • 14.81K
  • 622
  • 1.43K
Message 4 of 10
If the remote management port is 8443 you could change that.
  • 5
Message 5 of 10
Thanks for the speedy responses so far!
Sorry, am a bit daft, I can't find where the remote management setting is on the router, however I'm logging on the router via port 80? Thanks again!
  • 14.81K
  • 622
  • 1.43K
Message 6 of 10
Being the CGNV4-BIZ it may not have one? this forum deals with hubs that are not part of a business.
  • 3.67K
  • 288
  • 516
Superfast
Message 7 of 10
Could you use a different port for incoming? 8443 could be used for remote management, which I'm unsure if you can change.
https://www.speedguide.net/images/hardware/hitron/hitron-cgnv4-ug.pdf
  • 5
Message 8 of 10
OK thanks - ok where can I get support for business hubs please?
  • 5
Message 9 of 10
Hello, thanks for your response! I tried port 8888 but same problem? Thank you!
  • 25.12K
  • 1.44K
  • 3.2K
Message 10 of 10
Contact the business support team
