Ptolomed
CAT 6 Connection
Will CAT connections only work from the main connected router or can you plug into second box where it says internet, for the feed?
  • 16.32K
  • 713
  • 1.6K
Re: CAT 6 Connection
If you got a new router you connect the internet port to the hub and connect everything else to the new router and change hub to modem mode.
https://www.virginmedia.com/help/virgin-media-hub-modem-mode
Ptolomed
I have 2 virgin hubs, the main one has several ports, the other only one. The cat 6 is plugged into the second box with only one port available, shouls it still work off second box? Is the second box I need to  change to modem mode?
g0akc
  • 999
  • 92
  • 197
Well-informed
Which hubs are they?  Model number? Is one a 'booster' or something?
What are you trying to do?
I know a bit about Wi-Fi, Telecoms, and TV as I used to do it for a living but I'm not perfect so don't beat me up... If you make things you make mistakes!
