on 15-06-2021 20:38
I have a Virgin Media Hub 3.0 and V6 TiVo box. About 5 months ago, I purchsed my own WiFi 6 router. I successfully booted the MH into modem mode and encountered no problems with Internet or TiVo connectivity. However, I've moved a load of stuff around and I cannot now, for the life of me, get the TiVo to play nice with the router.
I've tried multiple start-up sequences but, in all cases, I either end up with the TiVo working fine but no Internet (via my router) or full Internet with a C130 error on the TiVo box. In the latter case, I am able to watch TV fine and access other services on the TV (Netflix, etc.) but I cannot watch On Demand or get TV listings.
I'm sure it's just the boot order but any help would be much appreciated.
Thanks.
Answered! Go to Answer
on 15-06-2021 20:50
If you are using a wireless connection on the V6 you must remove the ethernet cable from the back of the V6 as it' sees that and thinks the ethernet cable is connected to the hub/router and won't search for the wifi.
What does the V6 say when click on Home > Help & Settings > Settings > Network
Select Connection in progress: get status
Check when it says it was last connected, usually around every 5 or 6 hours. and try Connect to the Virgin Media Service now
With the ethernet cable pulled out you should be able to get the wifi connection (check you have correct SSID and password)
on 15-06-2021 20:50
on 15-06-2021 20:54
That sorted it - cheers!
on 15-06-2021 20:56
