Smokey999
  • 21
Buffering on wired Ethernet connection 100 MB’s
Hi guys I’m having trouble with buffering whilst watching you tube .I can’t understand why as I’ve got wired connection on 3 TVs .I also have 12 devices connected to hub.
speedtest shows I’m getting the speed ok.I’m looking to connect 4 cameras to Ethernet so I’m looking for a clean connection.
what’s the best solution?
  • 2.92K
  • 222
  • 625
Trouble shooter
Re: Buffering on wired Ethernet connection 100 MB’s
Setup a BQM here  www.thinkbroadband.com/ping    Also post your power levels and network log for comment.
As for the camera's I would suggest you look at PoE with a suitable PoE switch.  Less cables and power supplies needed.
