GL22tivo
  • 13
Message 1 of 12
Broadband speed
Hi, I have been upgraded from 350 Mbs to 600 Mbs.
On 350 Mbs, I was getting Wi-Fi speed between 320 Mbs amd 380 Mbs.
With 600 Mbs, I now get Wi-Fi speed between 150 Mbs and 260 Mbs.
I have the Hub 3 in Modem/Router mode.
Do I need the Hub 4?
lotharmat
  • 947
  • 70
  • 143
Well-informed
Message 2 of 12
Re: Broadband speed
What speed do you get with an ethernet cable?
RR-IT-GUY
  • 200
  • 11
  • 31
Superfast
Message 3 of 12
Re: Broadband speed
You may be given a HUB 4 if your area has been upgraded and the network is congested.
However if GIG 1 is not available in your area chances are you won't get one.
You should not need a HUB 4 although it would be a benefit to ask if your area has them available as they do have a bit of extra power.
Would you be able to go to your hubs status page at 192.168.0.1 and in modem mode 192.168.100.1 (unless it is different) copy and paste the router stats the confidential IP's will be removed automatically when you press post.
You may be required to log in using your password or the default on the bottom of the hub.
Molly_G
  • 421
  • 23
  • 53
Message 4 of 12
Re: Broadband speed
Hi @GL22tivo,
Thanks for your post and sorry to hear that you're getting poorer speeds since your upgrade.
Just to know how we can help further, could you confirm if these speeds were recorded via ethernet connection? Also, are you also experiencing the same speed issues when you take your Hub 3 out of modem mode?
Also, I'd suggest following the advice given by RR-IT-GUY and post your hub stats here so we have a better idea of what's going on and can advise you best.
Keep us posted!
Molly_G
GL22tivo
  • 13
Message 5 of 12
Re: Broadband speed
Thanks, for all the replies - apologies, for not getting back to you, before now - work gets in the way of life.
First request, was to get speeds using direct ethernet cable connections.
I did this 4 times - the first 2 were good, the last 2 were poor:
   672, 651, 270, 251
The second request, was to provide network stats - I'm not sure what/where this is.
This is the screen shot of where I got to.
Which TAB should I use, to provide the requested data?
Thanks, again for all your help/advice.
  • 8.15K
  • 650
  • 1.43K
Message 6 of 12
Re: Broadband speed
All tabs
Zak_M
  • 3.54K
  • 226
  • 353
Message 7 of 12
Re: Broadband speed
Good afternoon @GL22tivo
Could you copy and paste all of your router stats for us?
Kind regards,
Zak_M
GL22tivo
  • 13
Message 8 of 12
Re: Broadband speed
Hi Zak_M.
Where do I find the router stats?
Steven_L
  • 4.67K
  • 340
  • 463
Message 9 of 12
Re: Broadband speed
Hey @GL22tivo
You can find the stats by following the below instructions.
In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) and hit return. On the first page up [there should be no need to login if you have done so before]
click on the “router status” icon/text at bottom-middle of first page up and then copy/paste 3 FULL sets of data onto here – from the Downstream, Upstream, & Network Logs pages.
Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses.
Steven_L
GL22tivo
  • 13
Message 10 of 12
Re: Broadband speed
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
139000000
-0.7
40
256 qam
1
2
147000000
-0.5
40
256 qam
2
3
155000000
-0.7
40
256 qam
3
4
163000000
-0.9
40
256 qam
4
5
171000000
-1
40
256 qam
5
6
179000000
-1.2
40
256 qam
6
7
187000000
-1.2
40
256 qam
7
8
195000000
-1.2
40
256 qam
8
9
203000000
-1.5
40
256 qam
9
10
211000000
-1.7
40
256 qam
10
11
219000000
-1.7
40
256 qam
11
12
227000000
-2
40
256 qam
12
13
235000000
-2.2
40
256 qam
13
14
243000000
-2.5
40
256 qam
14
15
251000000
-2.7
40
256 qam
15
16
259000000
-2
40
256 qam
16
17
267000000
-1.5
40
256 qam
17
18
275000000
-1.5
40
256 qam
18
19
283000000
-1.5
40
256 qam
19
20
291000000
-1.5
40
256 qam
20
21
299000000
-1.4
40
256 qam
21
22
307000000
-1.5
40
256 qam
22
23
315000000
-1.7
40
256 qam
23
24
323000000
-1.7
40
256 qam
24
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40.9
453
0
2
Locked
40.3
503
0
3
Locked
40.3
489
0
4
Locked
40.9
350
0
5
Locked
40.3
8026
52
6
Locked
40.9
621
0
7
Locked
40.3
705
0
8
Locked
40.9
686
0
9
Locked
40.3
518
0
10
Locked
40.3
495
0
11
Locked
40.3
680
0
12
Locked
40.3
772
0
13
Locked
40.3
1559
15
14
Locked
40.3
670
10
15
Locked
40.3
1038
0
16
Locked
40.9
545
0
17
Locked
40.3
447
0
18
Locked
40.9
513
0
19
Locked
40.9
453
0
20
Locked
40.3
391
0
21
Locked
40.9
343
0
22
Locked
40.9
462
0
23
Locked
40.9
333
0
24
Locked
40.9
373
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
39400000
50
5120
64 qam
4
2
46199995
50.3
5120
64 qam
3
3
32600000
49.8
5120
64 qam
5
4
25800030
49.3
5120
64 qam
6
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
7
0
2
ATDMA
0
0
7
0
3
ATDMA
0
0
6
0
4
ATDMA
0
0
8
0
SFID
114006
Max Traffic Rate
690000278
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
114005
Max Traffic Rate
44000278
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
BestEffort
Time
Priority
Description
18/04/2021 15:22:55
notice
LAN login Success;CM-MAC=xxxxxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
18/04/2021 08:52:21
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=xxxxxxxxxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
17/04/2021 15:08:36
critical
No Ranging Response received - T3 time-out;CM-MAC=xxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
14/04/2021 20:52:21
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=xxxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
12/04/2021 04:58:12
critical
No Ranging Response received - T3 time-out;CM-MAC=xxxxxxxxxx;CMTS-MAC=xxxxxxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
11/04/2021 08:52:21
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=xxxxxxxxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
10/04/2021 22:48:20
critical
No Ranging Response received - T3 time-out;CM-MAC=xxxxxxxxxxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxxxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
07/04/2021 20:52:21
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=xxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
05/04/2021 00:31:27
critical
No Ranging Response received - T3 time-out;CM-MAC=xxxxxxxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
04/04/2021 08:52:21
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=xxxxxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
03/04/2021 15:24:35
critical
No Ranging Response received - T3 time-out;CM-MAC=xxxxxxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
31/03/2021 20:52:21
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=xxxxxxxxxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
29/03/2021 01:02:11
critical
No Ranging Response received - T3 time-out;CM-MAC=xxxxxxxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
28/03/2021 08:52:21
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=xxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
25/03/2021 15:28:42
critical
24/03/2021 20:52:21
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=xxxxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
23/03/2021 04:41:7
critical
No Ranging Response received - T3 time-out;CM-MAC=xxxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
21/03/2021 09:38:49
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=xxxxxxxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
18/03/2021 00:11:8
critical
No Ranging Response received - T3 time-out;CM-MAC=xxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
18/03/2021 00:10:24
critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=xxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
