  • 16
Message 1 of 27
Broadband speed
I have 500mb virgin broadband package and average speeds of 80mb, best speed 230mb, achieved once, right next to router, constant drop outs and short distance on the 5ghz network. I have better distance using the 2.4ghz but a much slower speed. The router is in the open and not blocked or next to mirror etc. I have changed the network's so they are separate ie 5ghz and 2.4ghz.
I have restarted the box on a number of times and still the speed is nowhere near what I am actually paying for.
Hopefully a virgin representative will be looking at this and will hopefully be able to resolve this.
I'm pretty sure the Hub 3.0 is the problem and hopefully the new hub 4.0 is better.
Neil
  • 3.55K
  • 570
  • 1.4K
Message 2 of 27
Re: Broadband speed
You won't get anywhere near 500 Mbps with most real world wireless devices.  Over 2.4 Ghz most connections top out around 80 Mbps, so what you see is normal, and on 5 GHz, the best tends to be 180-290 Mbps.  If you expected 500 over wifi, I'm afraid that won't happen any time soon until the Wifi 6 standard is supported.  And the Hub 4 is as disappointing in wireless terms as the Hub 3.
From a reliability perspective you might get better performance from a decent router or mesh system, but peak speeds won't be changed because they're limited by a whole range of factors.  Even if you bought a brand new WiFi 6 router, unless your wireless devices support that then you won't see any speed improvement.
  • 16
Message 3 of 27
Re: Broadband speed
I realise I won't be in reality able to achieve 500mb but, they do tend to forget to mention this in the sales dept.
I am rather less happy about the 80mb, as according to there own literature they should gaurantee a minimum of 285mb, and the drop outs are a real pain. They have said I need an extender, although they can't supply these at the moment
They could more to help
  • 30.42K
  • 1.52K
  • 5.29K
Message 4 of 27
Re: Broadband speed
they can only guarantee speed by wired. the speed they guarantee is the speed tot he hub. What you do on the internal network is out of there control as is wireless. This is pretty much the same across the board.
The only reason BT get less complaints about wireless is with a max speed to most of 80mbps wireless can hit that. With VM speeds of 500-1000 wifi will never get that speed
  • 16
Message 5 of 27
Re: Broadband speed
As I said in my earlier reply, it's a shame they don't mention this when they sell you the 500mb package, and extremely difficult to get a straight forward answer after you've purchased the package. I'm looking at mesh systems to improve the coverage and consistency, although that in itself is a minefield.
I would like to try a replacement hub, but finding it difficult to get hold of someone to speak about this.
  • 30.42K
  • 1.52K
  • 5.29K
Message 6 of 27
Re: Broadband speed
Why would they tell you if they are not forced to?
Buy our speed. Oh and by the way you will never get it on the wireless.
  • 16
Message 7 of 27
Re: Broadband speed
Well I suppose honesty would be nice, but as you implied to hide the truth is obviously a far better way to sell substandard services
  • 20.96K
  • 1.14K
  • 2.7K
Message 8 of 27
Re: Broadband speed
You can get over 500Mbps over WiFi with a device that supports such speeds
However don’t expect it on a 500Mbps connection for a start due to overheads etc
And there is no “honesty” to WiFi speeds since every household and the surrounding environment is different therefore it cannot be guaranteed.
  • 16
Message 9 of 27
Re: Broadband speed
Sadly it doesn't make up for the fact that they don't explain any of this to you, they just hold up the magic 500 figure and tell you how much better it is than any other supplier. On a phone call to one of there technians they actually said it could be a faulty hub, at no point did they explain that you would never achieve what they are advertising.
I have been with Virgin, expect for a couple of years, for at least 16 years and they have never had the best support, but this is the first time I've had to put up with average speeds at only 25% of the speed I am supposedly paying for.
So yes I have to say that they are deceiving people at the sales stage and quietly disappear when there are problems
  • 20.96K
  • 1.14K
  • 2.7K
Message 10 of 27
Re: Broadband speed
Actually on the speed guarantee website it states that WiFi speeds are not covered and it’s the speed delivered to the hub that is and that it also doesn’t apply during outages
https://www.virginmedia.com/shop/the-legal-stuff/virgin-media-speed-policy
Don’t forget, our minimum guaranteed download speed is to your Virgin Media Hub, not the device you’re using WiFi on. Even when using a wired connection, some older devices might not support our fastest speeds.
