Toddy14
  • 8
Broadband slow since upgraded my speed
Been on the phone to virgin constantly. I had the 200 mbps, and recently upgraded to the 500 mbps. Since then my wifi has became very slow, virgin sent a new hub 3 to me, this didn’t make any difference then an engineer came out and moved the hub from a cupboard to behind the tv. This has now made things worse and I have lost wifi in a room that had this before. I also have virgin media wifi booster installed. I have ran an Ethernet cable from the hub to my laptop and also PS4 and the most a Speedtest has managed is 190 mbps so I can’t get to the guaranteed speed of 256 mbps on a wired connection. The testing device is a gaming pc and capable of handling 1Gbs and using a Cat 5E/6 cable.
I am being sent out the new wifi pod to try and fix things, I was wondering if someone could have a look over the router details as I think there might be an issue with the cabling or the power coming in via the cables.
thanks
gary_dexter
  • 29K
  • 1.77K
  • 3.79K
Re: Broadband slow since upgraded my speed
Post the network, upstream and downstream logs from the hubs admin pages back here as text please
Toddy14
  • 8
1331000000840256 qam25
22030000009.140256 qam9
32110000009.340256 qam10
42190000009.140256 qam11
52270000008.940256 qam12
62350000008.640256 qam13
72430000008.340256 qam14
82510000008.540256 qam15
92590000008.540256 qam16
102670000008.540256 qam17
112750000008.540256 qam18
122830000008.640256 qam19
132910000008.540256 qam20
142990000008.840256 qam21
153070000008.440256 qam22
16315000000840256 qam23
173230000007.840256 qam24
183710000006.940256 qam26
193790000006.640256 qam27
203870000006.540256 qam28
213950000006.540256 qam29
224030000006.540256 qam30
234110000006.640256 qam31
244190000006.540256 qam32
1Locked40.950
2Locked40.360
3Locked40.350
4Locked40.950
5Locked40.950
6Locked40.300
7Locked40.900
8Locked40.930
9Locked40.340
10Locked40.300
11Locked40.970
12Locked40.960
13Locked40.970
14Locked40.950
15Locked40.960
16Locked40.300
17Locked40.9170
18Locked40.950
19Locked40.300
20Locked40.960
21Locked40.950
22Locked40.950
23Locked40.360
24Locked40.350
Toddy14
  • 8
13940000043.8512064 qam4
24620000044512064 qam3
36030000044512064 qam1
45370000044512064 qam2
3ATDMA0000
4ATDMA0000
Toddy14
  • 8
18/01/2021 14:04:23noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/01/2021 13:30:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/01/2021 11:19:40noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/01/2021 09:11:19criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2021 08:20:45noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2021 08:04:44Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2021 08:04:40criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2021 08:04:40Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2021 08:04:39criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2021 08:03:37Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 10:31:9noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 17:37:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/01/2021 23:09:3Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/01/2021 03:22:56criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/01/2021 01:25:0noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:02:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:02:29noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/01/2021 01:17:42noticeSW download Successful - Via NMS
13/01/2021 01:15:53noticeSW Download INIT - Via NMS
Steven_L
  • 4.06K
  • 302
  • 396
Hey @Toddy14,
Sorry to hear of the issues that you've been having with your connection.
I have been able to locate your account and can see that you have had a technician visit earlier today.
Is everything working as it should for you now?
Steven_L
