  • 26
Broadband network issue
Hi I woke up this morning to find my network were no longer sharing anything between devices I've checked all settings on all devices but none are showing up in network so I can connect to them via another device also my main desktop is on wire and the router and connection keep disappearing for couple seconds every 3 to 5 mins whereas wifi devices they are staying connected I'm so confused on this problem ive reset the router and pinhole reset it ive tried ringing but limited on time I can spend waiting any help would be great thanks if needed I can try post images
  • 24.94K
  • 1.44K
  • 3.17K
Re: Broadband network issue
What does the service status page show?
