James53646
Broadband keeps losing connection.
Hi All,
I’ve been having issues over the last week where my internet connection keeps dropping out for long periods of time.
I've got the 200mbp connection. It used to run at that speed all the time, now on a good day it’s around 30mbps but the main problem is when it drops to 1 or 2 mbps for 10 mins or drops out all together.
All our devices are wireless and we’ve not added anything new which could cause problems or bought anything new that could interfere with the signal?
I’ve reset the hub but again got the same problem?
I can’t seem to find a number to talk with someone at Virgin and have tried all there troubleshooting.. check cables and all that?
I’m paying good money for this and don’t seem to be getting anywhere.
Can anyone help?? Or at least does anyone have a number I can call to complain to Virgin??
Thanks for the help!!
James
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Re: Broadband keeps losing connection.
A bit more information is required, please post the following ...
Please do this before posting the Hub Data
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
Please do not use screen shots.
gary_dexter
  • 28.88K
  • 1.76K
  • 3.78K
What are speeds like on wired devices and do these also drop off at the same time?
