htatla
  • 21
Message 1 of 14
Broadband keeps cutting out
I’m having dropout trouble with my Broadband which keeps on cutting out since “Lockdown 2” started - so around Nov time
My internet connection will cut out/reconnect and repeat this cycle every 5-10min depending on how bad it’s behaving. On the Superhub router - the green WiFi logo will appear solid once down, and then flicker randomly until it’s back up, usually within a few mins.
Streaming videos becomes effected which you have to go back and play again after each dropout. WFH is severely effected for me now with video calls cutting out every few mins so this is the main frustration and issue.
i have read some posts about creating a “network monitor” which I have just done - I also need to test on Ethernet to see if it’s WIFi related or not
i have had 4 x engineers out to the property since Nov and no fix as yet. They changed some wiring and some connectors, tinker with the hub etc to no avail so I think it’s not an issue in my property but at the box or further upstream
  • 26.52K
  • 2.7K
  • 4.92K
Message 2 of 14
Re: Broadband keeps cutting out
You say you have a "Superhub" is that an SH1/2/2ac? Or do you mean a Hub3/Hub4?
Do test on an ethernet connection and report back. It may be just a wifi issue or something your BQM might reveal - post up a link to the "share live graph" once its running.
htatla
  • 21
Message 3 of 14
Hi i have a Superhub 3
Yes will try Ethernet and report back - will try streaming a video on the V6 box the next time it happens as this is Ethernet hard-wired
Links to my BQM (just under 24hrs as of writing)
https://www.thinkbroadband.com/broadband/monitoring/quality/share/f60d826156eff1c0bc4ca111518fd8057a5ec1d2
 Live graph if html is allowed 😉
<a title="Broadband Ping" href="https://www.thinkbroadband.com/broadband/monitoring/quality/share/f60d826156eff1c0bc4ca111518fd8057a5ec1d2"><img alt="My Broadband Ping - VM Broadband monitor" src="https://www.thinkbroadband.com/broadband/monitoring/quality/share/f60d826156eff1c0bc4ca111518fd8057a5ec1d2.png" /></a>
htatla
  • 21
Message 4 of 14
Just had a dropout while streaming a movie at 12:20am - hope this helps for checking my BQM
gary_dexter
  • 31.34K
  • 1.94K
  • 4.22K
Message 5 of 14
Nothing on the BQM no
htatla
  • 21
Message 6 of 14
Yesterday was faultless (30/12) but from 1pm today (31/12) it’s now cutting out every 5mins like clockwork
appreciate any help
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 7 of 14
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
htatla
  • 21
Message 8 of 14
sure thank you :-
14350000003.237256 qam4
24110000003.737256 qam1
34190000003.737256 qam2
44270000003.537256 qam3
54430000003.438256 qam5
64510000003.737256 qam6
74590000003.537256 qam7
84670000003.437256 qam8
94750000003.538256 qam9
104830000003.538256 qam10
114910000002.737256 qam11
12499000000337256 qam12
13507000000337256 qam13
145150000002.737256 qam14
15523000000337256 qam15
165310000003.238256 qam16
17539000000337256 qam17
185470000002.537256 qam18
195550000003.237256 qam19
205630000003.237256 qam20
21571000000337256 qam21
225790000003.237256 qam22
235870000003.437256 qam23
245950000002.737256 qam24
1Locked37.66020
2Locked37.65730
3Locked37.660714
4Locked37.65120
5Locked38.65740
6Locked37.66220
7Locked37.679014
8Locked37.67280
9Locked38.68740
10Locked38.68470
11Locked37.313520
12Locked37.614750
13Locked37.616150
14Locked37.618850
15Locked37.616500
16Locked38.616050
17Locked37.624310
18Locked37.629200
19Locked37.625000
20Locked37.630280
21Locked37.631700
22Locked37.637100
23Locked37.6350013
24Locked37.641340
16030000044512064 qam1
23940000044512064 qam4
34620000044512064 qam3
45369999344512064 qam2
1ATDMA0020
2ATDMA0010
3ATDMA0030
4ATDMA0010
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
A,.iyewrkldJKDHSUBsgvca69
SFID10986
Max Traffic Rate575000000
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID10985
Max Traffic Rate38520000
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
31/12/2020 13:43:11noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2020 06:40:21criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 18:07:33noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 18:07:33ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 23:48:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 00:39:4noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/12/2020 21:27:50criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/12/2020 22:07:27noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/12/2020 17:58:48criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/12/2020 21:32:35noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/12/2020 21:32:35ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/12/2020 13:12:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2020 17:51:17noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2020 17:51:9Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2020 17:48:55noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2020 16:21:59criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2020 13:21:35noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2020 13:21:35ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/12/2020 01:15:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/12/2020 16:14:20Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
htatla
  • 21
Message 9 of 14
thanks as below - hope this helps!
24110000003.537256 qam1
44270000003.437256 qam3
104830000003.438256 qam10
175390000002.937256 qam17
19555000000337256 qam19
22579000000337256 qam22
1Locked37.66050
2Locked37.65780
3Locked37.361114
4Locked37.35170
5Locked38.65780
6Locked37.66270
7Locked37.679514
8Locked37.67300
9Locked38.68830
10Locked38.68510
11Locked37.313580
12Locked37.614860
13Locked37.616230
14Locked37.618890
15Locked37.616590
16Locked38.616160
17Locked37.624440
18Locked37.629340
19Locked37.625230
20Locked37.630430
21Locked37.631850
22Locked37.337400
23Locked37.6352413
24Locked37.34155
0
1ATDMA0020
2ATDMA0010
3ATDMA0030
4ATDMA001
0
htatla
  • 21
Message 10 of 14
and the rest ...
Network access
Allowed
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
SFID10986
Min Traffic Rate0
SFID10985
Min Traffic Rate0
Scheduling Type
BestEffort
