  • 5
Message 1 of 10
Broadband - keep losing wifi - many devices
I did a factory rest a couple of weeks ago, and I moved the router about 3 days ago
It is particularly noticeable across Amazon echos (Alexa) and FireTV, across 2.4 & 5. The 2.4 network is currently showing as “not in range”
It’s so inconsistent that I’m now looking for alternative suppliers, esp as V support by phone is really poor. In the meantime, does it look as though I need a new or updated router, or is there a better fix? Thanks
  • 24.94K
  • 1.44K
  • 3.17K
Message 2 of 10
Re: Broadband - keep losing wifi - many devices
Moved the router how?
Did you use the Virgin supplied Coax cable?
Is it just Wifi that's disconnecting or do wired devices do it as well?
And lastly what hub model do you currently have?
  • 5
Message 3 of 10
I just moved it further away from TV and solid wall. Unplug - move - plug in.
Problems were arising before that move, and have got no better since.
Hub3. No problems with wired.
  • 24.94K
  • 1.44K
  • 3.17K
Message 4 of 10
OK
Have you disabled the "Smart" wifi and split the wifi bands, changed to less congested channels etc?
  • 5
Message 5 of 10
Not sure what you mean by smart WiFi, but I use main channel for 5, and set up a new one for 2.4
  • 7.71K
  • 462
  • 486
Message 6 of 10
Hi KevMcp,
Very sorry for the Wi-Fi issues you've been having and for the delay in getting in touch.
Due to the delay can I ask if you're still having issues now?
I have had a look into the back end of things and it is showing some recent device instability but it also doesn't show any devices connected.
Please let us know how you're getting on so we can help further if needed.
Emma_C - Forum Team
  • 5
Message 7 of 10
Hi Megan
Thanks for getting back to me. Here are some observations:
Router is still being erratic. Right now, I have no wifi, as the router seems to have restarted itself (this is worrying, as I have an online interview next week (no work since April!))
I’m surprised you found nothing connected. We usually have a a desktop, but it has been having connectivity problems (DNS server, which I’m assuming relate to that device, not the router, but I could be wrong).
In summary, connections to router are no longer reliable. This has been going on for many weeks - should I ask for a new router?
Thanks again
Kev
  • 12.06K
  • 939
  • 1.54K
Message 8 of 10
Mike Robinson
  • 12.06K
  • 939
  • 1.54K
Message 9 of 10
Can you please
Mike Robinson
  • 5
Message 10 of 10
Hi Emma
Megan
Router is still being very erratic. Right now, I have no wifi, as the router seems to have restarted itself (this is worrying, as I have an online interview next week (no work since April!))
I’m surprised you found nothing connected. We usually have a a desktop, but it has been having connectivity problems (DNS server, which I’m now thinking is a related problem).
In summary, connections to router are no longer reliable. This has been going on for many weeks - I think I just need a new router?
Thanks again
