lotharmat
  • 3.85K
  • 259
  • 724
Community elder
Message 21 of 25
Re: Broadband issues
SNR = Signal to noise ratio
Signal = good
Noise = unwanted!
If the SNR gets too low - the modem won't be able to adequately hear the signal over the noise and you lose packets (parts of the conversation)
Nats19
  • 14
Message 22 of 25
Ok thanks for confirming. If it still persists past the date mentioned, shall I just jump back on here to report it?
Nats
lotharmat
  • 3.85K
  • 259
  • 724
Community elder
Message 23 of 25
Absolutely!!!
Nats19
  • 14
Message 24 of 25
Hi there,
I hope you're well.
I am still experiencing issues on this. Yesterday was fine and the wi-fi was running without any issues, it was a bit slow, but working. Today, the signal keeps on dropping out.
Can you help, again?
Nats
Molly_G
  • 1.15K
  • 53
  • 136
Message 25 of 25
Hey @Nats19,
Thanks for dropping back. Unfortunately the work has been extended to fix this fault in your area.
The updated estimated fix time is now: 17th June at 11am.
Apologies again for the push back and the disruption this has caused.
Kind regards,
Molly_G
