Nats19
  • 14
Message 1 of 25
Broadband issues
I’ve had wi-fi/broadband issues for the past week. It dips in and out, the network number vanishes from my screen and then can’t be located. It then reappears and does the same thing over again.
I’ve checked the wires, plugs, everything and all is attached.
Can you help please?
Nats
lotharmat
  • 3.85K
  • 259
  • 724
Community elder
Message 2 of 25
Re: Broadband issues
What happens to wired connections? (ethernet)
Nats19
  • 14
Message 3 of 25
Hello,
Sorry I am not techie at all. What do you mean?
Nats
lotharmat
  • 3.85K
  • 259
  • 724
Community elder
Message 4 of 25
If you are using a laptop - You should have an ethernet cable that plugs into the back of the hub and then into a port on your laptop (looks like the same port as on the back of the hub)
If you still have internet when wifi fails then the issue has been narrowed down to wifi as opposed to the actual signal coming into the hub.
Nats19
  • 14
Message 5 of 25
Thanks for getting back to me.
I am working off both a laptop and a screen with keyboard. When the wi-fi goes down so does the internet. There’s nothing at all.
lotharmat
  • 3.85K
  • 259
  • 724
Community elder
Message 6 of 25
No problem - does the laptop only get internet access by WiFi?
Can you post your Hub status and logs?
Someone should be spot if there is a problem
Navigate to http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) in a web browser
Don't log in!
Click on 'router status'
Copy/paste the data from each of the tabs. The forum software will remove the MAC addresses for you (you may need to click the 'post' button again).
Also, set up a 'Broadband Quality Monitor'. This will monitor the state of your connection and record any network dropouts etc - You can do this at ThinkBroadband (https://www.thinkbroadband.com/broadband/monitoring/quality)
Give it a while to gather data and then click 'Share Live graph' and paste the 'Direct Link' into the forum!
Nats19
  • 14
Message 7 of 25
Hi there,
Sorry for the delay. Yes the laptop only runs when there’s wi-fi. I am currently at my parents place and the wi-fi is running fine, so would this be a router problem?
I’ll try the link below and will see what happens.
Nats
gary_dexter
  • 32.63K
  • 2.01K
  • 4.46K
Message 8 of 25
You need to test with a wired/ethernet connection from your laptop.
Nats19
  • 14
Message 9 of 25
330750000
Locked
Ranged Upstream Channel (Hz)
53700000
Locked
Provisioning State
Online
15370000042.3512064 qam1
23260000043.8512064 qam4
33940000043.8512064 qam3
44620000043.3512064 qam2
2ATDMA00260
3ATDMA00532
4ATDMA00561
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
rkldJKDHSUBsgvca69834ncxv
SFID846
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID845
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
lotharmat
  • 3.85K
  • 259
  • 724
Community elder
Message 10 of 25
Those T3 timeouts are a problem! - This needs VM to take a look -
In the meantime, can you post up the downstream data as well!
I think, so far, from this data we can confirm that it is a general connection problem as opposed to just WiFi!
