  • 18
Message 1 of 17
Broadband issues
Hi everyone . i am desperate for some help or answers to this issue that i am having with my Virgin service .  Everyday since i was connected for the full package i have been having the same problems with my WIFI switching off regulary this is happening everyday and i have tried doing all of the trouble shooting advice from Virgin ( ie resetting hub etc ) running tests etc . i was supposed to be getting an engineer to come and check but Virgin cancelled it saying that they had resolved the issue using the online tests . i have tried phoning the helpline number 0333 000 3101 but thats not very helpful as that just tells you to run more tests etc . Look when i am paying decent money for a service i think that it should be reliable and i am serously thinking of cancelling .
  • 12.3K
  • 952
  • 1.58K
Message 2 of 17
Re: Broadband issues
Which Hub do you have ?
What is your contracted speed ?
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
Mike Robinson
  • 25.21K
  • 1.45K
  • 3.21K
Message 3 of 17
You don’t pay for Wi-Fi though.
What are wired connections like?
  • 18
Message 4 of 17
Hi i think that you are paying for the WIFI service in your own home . how do you think that your mobile device's connect to the internet also when i was with BT  there was never any issues with the signals any where in the home also i was able to sit outside in my garden and use my laptop pc without any problems so i think that you should read my question again.
  • 25.21K
  • 1.45K
  • 3.21K
Message 5 of 17
No. You pay for the connection to your home and then to your hub. The speed guarantee only covers you for connections made with a compatible wired device.
So again, what are speeds and connectivity like with wired devices?
  • 18
Message 6 of 17
Hi . i think that i am on the 516mbs package and the only thing that is connect to the hub with ethernet cable is my Smart tv everyting else is using the wifi network . i had no issues when i had BT and i had upto 8 devices all working perfect .
  • 25.21K
  • 1.45K
  • 3.21K
Message 7 of 17
That was BT. This is Virgin. Different hardware and different cable technology.
  • 12.3K
  • 952
  • 1.58K
Message 8 of 17
You are paying for a broadband connection to the Virgin Media Hub.
vm-speeds
Mike Robinson
  • 18
Message 9 of 17
Yes i know that . but i think that the service is crap. you can't phone anyone to discuss any problems . All you get is text messages telling you to run tests that are not solving the issues . And if you think that Virgin are a better service i would have to disagree with you at this time .
  • 25.21K
  • 1.45K
  • 3.21K
Message 10 of 17
No one will assist with Wi-Fi issues.
If you want better Wi-Fi you can put the hub into modem mode and use your own router or mesh system to improve the Wi-Fi to your requirements.
