  • 7
Message 1 of 13
Broadband issues
I am having issues with my broadband. Since it install 3 months ago, my broadband drops about twice daily. I have the main hub in my living room and a booster in my bedroom. When I'm in the living room I connect to the main hub, but if I walk 10 feet to my bedroom the WiFi doesn't work, I need to connect to the booster. If I go to the bathroom there is no WiFi signal at all. I have reset the hub so many times but still doesn't fix the issue. If I do a service check it says everything is working fine. I've tried to report the issue but can't get to speak to anyone due to the current pandemic. I was with Sky before I changed over to VM and there was no issue with the broadband, it worked in every room and was great. The reason I changed was VM were giving me the same offer but £40 cheaper per month. Now I regret going to VM.
  • 24.28K
  • 1.39K
  • 3.09K
Message 2 of 13
Re: Broadband issues
What are wired connections like? Do they also drop?
  • 7
Message 3 of 13
The additional box in the bedroom is wired to the booster, so when the main hub is down it affects the booster and wired V6 box in the bedroom. Everything was set up by a VM engineer including the boosters.
  • 24.28K
  • 1.39K
  • 3.09K
Message 4 of 13
Do the lights change on the hub when the connection drops?
  • 7
Message 5 of 13
At first the power button flashes white, then three green lights come on the hub. It can take between 2 and 10 minutes for the main hub to come back on again. This is almost twice a day its happening. I have reset the main hub 4 times but still same issues.
  • 24.28K
  • 1.39K
  • 3.09K
Message 6 of 13
Is there anything listed on the Service Status page?
  • 7
Message 7 of 13
There has been times that it says there is no issues and times it says there is an issue. The most recent one I checked was yesterday and says the hub is on line but there is an issue (whatever that means).
  • 1.66K
  • 85
  • 129
Message 8 of 13
HI Jokerharley1611,
Thank you for your post and welcome to the forums.
I am sorry for the delay in response here! It's not great to read some of the issues you've experienced here, I apologise for that. How has everything been since your post or have you managed to speak with the team since? Is it possible you could run a BQM and leave this running for over 24 hours so we can monitor the drop outs? This can be found; here
Cheers.
Ryan_N - Forum Team - https://community.virginmedia.com/t5/custom/page/page-id/WelcomeGoodFolk
  • 7
Message 9 of 13
Hi Ryan,
I have created a monitor account and added the details. Fingers crossed I've done it right and you can access my hub and monitor my connection.
I spoke to someone via text message and they said to reset the hub but its not made any difference. It still drops but every other day now. So hopefully with the monitor you can see whats going on and get more information than I can give you.
Cheers
  • 3.49K
  • 208
  • 268
Message 10 of 13
Morning Jokerharley1611,
Just checking in?
Were you able to set up a BQM?
Alex_Rm
