  • 7
Message 1 of 11
Broadband issues
Hello,
I am hoping that someone will be able to assist me, we have been virgin media customers for nearly 10 years, the WiFi signal has been pretty consistent since we joined, however for the last 6 months we have been struggling getting a decent signal, (I have added a BQM to show this) the only device we have wired is my PS4, it struggles doing any updates.
The cable on the driveway is also above ground and we have reported this before but have had no one assist us.
I have include picture of both the BQM from the 1st/2nd of November and also the picture of the cable (it was dark sorry its not the best quality)
Kind Regards,
Sam BQMBQMCableCable
Spoiler
  • 11.97K
  • 933
  • 1.53K
Message 2 of 11
Re: Broadband issues
Then
Can you please
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again. Use one post for each tab if you wish. Please do not use screen grabs.
Mike Robinson
  • 11.97K
  • 933
  • 1.53K
Message 3 of 11
What is your contracted speed ?
Which Hub do you have ?
What is your connection like using a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Mike Robinson
  • 7
Message 4 of 11
Good morning,
Thank you for your help,
here is the live BQM link
I will have to log into the router when I return from work.
Kind regards
Sam
https://www.thinkbroadband.com/broadband/monitoring/quality/share/da4d6f56a9a851512f75bda49514731954...
  • 7
Message 5 of 11
Sorry,
Just to add further, 100M and we have the hub3
Kind regards
Sam
  • 7
Message 6 of 11
Hello,
Sorry to pester, Is anyone able to assist me with these issues?
Kind regards,
Sam
  • 24.82K
  • 1.43K
  • 3.16K
Message 7 of 11
Forum reps can take a week or so to respond
  • 7
Message 8 of 11
Thank you for letting me know
  • 1.89K
  • 95
  • 176
Message 9 of 11
Thanks for reaching out Edgeworth11
Sorry to hear, you're having issues with your connection and internet quality.  I'd like to take a closer look on your behalf. To enable me to do so, I am going to send you a private message. Please look out for the purple envelope in the top right of the screen.
Lee_R
  • 7
Message 10 of 11
@lee_R
Hello Lee,
The Engineer did visit this past weekend, he changed the power cable (yes 100% the power cable) and said that will fix the issues.
As you can see via the latest BQM it has made 0 difference at all.
Please can you let me know how I can processed?
Kind Regard
Sam
