dspadini
  • 5
Message 1 of 9
Broadband issues: packet loss and high latency
Hi all,
since a couple of weeks ago I am having a packet loss at around 10% constantly, and high latency.
I setup a https://www.thinkbroadband.com/ account and the result is horrible:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/694f4e3e70868d3486e90b136ce7918fbfca3a7f-29-06-2021
I checked VM and it says in my area there aren't any problems.
I opened a ticket with them and they replied: "In this instance, advise you to contact our faults management centre if the issue persists so that we can perform diagnostics and fix the issue."
Of course, they didn't attach a phone number/email so I don't know how to proceed.
By checking another post (https://community.virginmedia.com/t5/Managing-Your-Account-Cable/How-can-I-report-a-broadband-fault/...), they suggest to post in this group.
What do you think could be the problem?
I already restarted my Hub 3, my router, disconnected everything, etc.
lotharmat
  • 2.54K
  • 189
  • 461
Trouble shooter
Message 2 of 9
Re: Broadband issues: packet loss and high latency
Can you post your Hub status and logs?
Someone should be spot if there is a problem
Navigate to http://192.168.0.1 (or http://192.168.100.1 - if in modem mode)
Don't log in!
Click on 'router status'
Copy/paste the data from each of the tabs. The forum software will remove the MAC addresses for you (you may need to click the 'post' button again).
dspadini
  • 5
Message 3 of 9
Status:
202750000
Locked
Ranged Upstream Channel (Hz)
60300000
Locked
Provisioning State
Online
Downstream:
1202750000-4.536256 qam9
2210750000-4.237256 qam10
3226750000-4.726256 qam12
4234750000-4.238256 qam13
5242750000-4.438256 qam14
6250750000-4.438256 qam15
7258750000-4.238256 qam16
8266750000-4.438256 qam17
9274750000-4.438256 qam18
10282750000-438256 qam19
11290750000-438256 qam20
12298750000-3.738256 qam21
13306750000-3.538256 qam22
14314750000-3.238256 qam23
15322750000-338256 qam24
16330750000-2.538256 qam25
17370750000-1.938256 qam26
18378750000-2.438256 qam27
19386750000-1.738256 qam28
20394750000-1.438256 qam29
21402750000-1.538256 qam30
22410750000-1.238256 qam31
23418750000-1.538256 qam32
1Locked36.311652
2Locked37.68721
3Locked26.84702485938871631
4Locked38.97227
5Locked38.6668
6Locked38.6903
7Locked38.610211
8Locked38.98612
9Locked38.63912
10Locked38.6373
11Locked38.6271
12Locked38.6341
13Locked38.9260
14Locked38.660
15Locked38.940
16Locked38.900
17Locked38.610
18Locked38.6141372
19Locked38.9180
20Locked38.9200
21Locked38.600
22Locked38.650
23Locked38.640
Upstream:
16030000051512064 qam1
23940000051512064 qam4
34620000051512064 qam3
45370000050.3512064 qam2
3ATDMA0000
4ATDMA000
0
dspadini
  • 5
Message 4 of 9
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt062+voc-b.cm
SFID46096
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID46095
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
29/06/2021 11:33:38Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2021 11:33:36Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2021 11:32:41Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2021 11:32:39Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2021 11:32:23Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2021 11:32:16Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2021 11:31:29Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2021 11:31:25Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2021 11:30:55Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2021 11:30:51Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2021 11:30:28Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2021 11:30:28Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2021 11:30:13Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2021 11:30:11Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2021 11:29:36Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2021 11:29:34Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2021 11:29:19Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2021 11:29:12Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2021 11:28:18Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2021 11:28:15Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
lotharmat
  • 2.54K
  • 189
  • 461
Trouble shooter
Message 5 of 9
Upstream power is too high and looks like some serious noise ingress on some downstream channels!
I'd say it needs an engineer to fix!
VM Should pick this up shortly!
dspadini
  • 5
Message 6 of 9
Thank you so much!
I will wait for them to contact me then 🙂
Kind regards
Sasha_W
  • 1.37K
  • 62
  • 112
Message 7 of 9
Hi @dspadini
Welcome to the forum page and thanks for posting this on here.
Sorry to hear you're having some issues, but from looking at your account it does look like you have spoken to our team recently to arrange an engineer, can I just confirm is everything all sorted for you or do you need our assistance today?
More than happy to help if so, but please do let us know 🙂
Sasha - Forum Team
dspadini
  • 5
Message 8 of 9
Hi Sasha, thanks for reaching out.
Yes, the engineer will come tomorrow to have a look! Hopefully it will be solved then 🙂
Kind regards
Sasha_W
  • 1.37K
  • 62
  • 112
Message 9 of 9
That's great to hear, thanks so much for letting us know!
Please do keep us updated!
Have a fab day!
Sasha - Forum Team
