Catsh
Settling in
Broadband issue
My broadband and WiFi is shutting down daily. When it works speed is fine then it just stops. My hun is old maybe I need a new one or an engineer. I have done all the resets etc and followed all online instructions
lotharmat
  • 770
  • 53
  • 108
Well-informed
Re: Broadband issue
Do wired connections drop as well at the same time as the Wireless?
Catsh
Settling in
Re: Broadband issue
We don’t use any wired connections
lotharmat
  • 770
  • 53
  • 108
Well-informed
Re: Broadband issue
What hub do you have - You're always best checking a wired connection if it is possible!
Do any lights appear on the hub when the WifI drops?
Catsh
Settling in
Re: Broadband issue
Hub3.0
Catsh
Settling in
Re: Broadband issue
There’s just a single red light at present
