Message 1 of 5
Broadband issue
I have a broadband issue. Why has the led light on my hub 3.0 turned yellow. Wifi intermittent at times but when I do a service status is says everything is okay. I have rebooted, switched off etc. What else can I do?
  • 922
  • 68
  • 127
Well-informed
Message 2 of 5
Re: Broadband issue
What colour was it before?
Mine is a kind of yellowish white. So it could be confused as 2 different colours.
Message 3 of 5
Re: Broadband issue
Before it was white
  • 3.52K
  • 567
  • 1.38K
Message 4 of 5
Re: Broadband issue
If it's "off-whitey-yellowy" then it could be the LED is ageing.  But I don't think so, most LEDs are very stable.
If you're having problems and you have the Yellow LED of Doom, then you'll need a new router.  From previous forum discussion, we believe that it indicates a publicly undocumented error state.  Hold on here and the forum staff should pick this up and arrange for you to get a replacement hub.
Message 5 of 5
Re: Broadband issue
Thank you.
