Broadband issue after power cut
Mjsmedl9000
I am experiencing broadband issues after a power cut. Initially only some apple products would connect following a 30 min power cut. I reset and hard reset the hub (it’s a hub 5) several times and now only some devices will connect (sonos and Google speakers) but my phone and smart tc won’t (iPhone and android tv) . Any advice welcome, I have turned it off and on and done the factory reset. Am at a loss as to how to make it work.
4 REPLIES 4
see this
________
First thing is to check for any “known network faults in your location - Try in 2 places
1) Try the “check service,”Area status webpage (https://www.virginmedia.com/help/service-status)
2) Then also Try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues and fix estimates, down to street cab/ postcode level.
Joseph_B
Hey @Mjsmedl9000,
Welcome back to the Community Forums and thanks for the post.
Sorry to see you are having these issues with your broadband, I can see you have spoken to our team since this post, were they able to provide any further information or help?
Joe
Hi there, yes it is sorted thank you. Not sure what the issue was but it works so it doesn’t matter. Thanks
Joseph_B
Hey @Mjsmedl9000,
Great to hear, if you do have any further issues or queries do let me know and we can always assist further with this.
Joe
