  • 9
Message 1 of 15
Broadband intermittent - lots of packet loss
I am in the Edinburgh area and trying to work from home.
For the last two days the packet loss has meant I am constantly getting kicked out from Skype and any other form of comms - including Slack, Teams and even Discord...
I've checked my system - connected directly to the HUB3 and rebooted everything multiple times.
I've been running pingplotter and seeing lots of dropped packets within the Virgin network .
Can anyone help ?
Phil
  • 25.12K
  • 1.44K
  • 3.2K
Message 2 of 15
Re: Broadband intermittent - lots of packet loss
Post the Network, Upstream and Downstream logs from the hub admin pages.
Also setup a BQM monitor.
  • 9
Message 3 of 15
Thanks for responding.
Info listed below. Please note that my connection OUT appears fine - however I am seeing lots of packet loss in the Virgin network. It would be fine for browsing and perhaps annoying for streaming - but for working  it is not fit for purpose.
- see the Pingplotter graph
  • 9
Message 4 of 15
Anbd Re: Broadband intermittent - lots of packet loss
BQM Link BQM graph - (the outage today was the reboot of the modem)
LOGS:
Network:
Time
Priority
Description
03/11/2020 03:37:52
critical
03/11/2020 03:37:51
Warning!
B-INIT-RNG Failure - Retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/11/2020 03:36:44
critical
03/11/2020 03:36:12
Warning!
03/11/2020 03:35:9
critical
03/11/2020 03:35:8
Warning!
03/11/2020 03:34:10
critical
03/11/2020 03:34:9
Warning!
03/11/2020 03:32:51
critical
03/11/2020 03:16:1
critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/11/2020 03:15:13
Warning!
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/11/2020 03:15:9
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/11/2020 03:15:9
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/11/2020 03:15:9
critical
03/11/2020 03:15:8
Warning!
03/11/2020 03:10:35
critical
DHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/11/2020 03:09:20
critical
03/11/2020 03:08:35
critical
DHCP FAILED - Request sent, No response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/11/2020 03:07:14
critical
03/11/2020 02:57:27
critical
Upstream:
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
39400000
44.5
5120
64 qam
4
2
32599976
44.5
5120
64 qam
5
3
46200004
44.5
5120
64 qam
3
4
53700034
46
5120
64 qam
2
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
Downstream:
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
411000000
-6.5
37
256 qam
31
2
203000000
-2.4
37
256 qam
9
3
211000000
-2.5
37
256 qam
10
4
219000000
-2.7
37
256 qam
11
5
227000000
-3.2
37
256 qam
12
6
235000000
-3.7
37
256 qam
13
7
243000000
-4.4
36
256 qam
14
8
251000000
-4.7
36
256 qam
15
9
259000000
-5.2
36
256 qam
16
10
267000000
-5.4
36
256 qam
17
11
275000000
-5.4
36
256 qam
18
12
283000000
-5.4
37
256 qam
19
13
291000000
-5.2
37
256 qam
20
14
299000000
-4.7
36
256 qam
21
15
307000000
-4.9
37
256 qam
22
16
315000000
-4.7
37
256 qam
23
17
323000000
-4.5
37
256 qam
24
18
363000000
-5
37
256 qam
25
19
371000000
-5
37
256 qam
26
20
379000000
-4.9
37
256 qam
27
21
387000000
-5.2
37
256 qam
28
22
395000000
-5.5
37
256 qam
29
23
403000000
-6.2
37
256 qam
30
24
419000000
-6.4
37
256 qam
32
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
37.3
8
0
2
Locked
37.3
5
0
3
Locked
37.3
19
0
4
Locked
37.6
22
0
5
Locked
37.3
21
0
6
Locked
37.3
21
0
7
Locked
36.6
12
0
8
Locked
36.6
8
0
9
Locked
36.6
23
0
10
Locked
36.6
10
0
11
Locked
36.6
8
0
12
Locked
37.3
12
0
13
Locked
37.3
13
0
14
Locked
36.6
25
0
15
Locked
37.3
26
0
16
Locked
37.3
20
0
17
Locked
37.3
3
0
18
Locked
37.3
1
0
19
Locked
37.3
7
0
20
Locked
37.6
8
0
21
Locked
37.3
23
0
22
Locked
37.3
17
0
23
Locked
37.6
8
0
24
Locked
37.3
7
0
  • 25.12K
  • 1.44K
  • 3.2K
Message 5 of 15
Re: Anbd Re: Broadband intermittent - lots of packet loss
Your downstream levels are too low. Is there an attenuator fitted to the back of the hub?
  • 9
Message 6 of 15
hi
Yes there is an attenuator fitted...
Is there something I should do to check it?
  • 25.12K
  • 1.44K
  • 3.2K
Message 7 of 15
Power off the hub and remove the attenuator.
Power the hub back on, give it a few minutes to settle then post the stats back again please.
  • 9
Message 8 of 15
Attenuator removed as requested and updated stats below
ChannelFrequency (Hz)Power (dBmV)Symbol Rate (ksps)Modulation
13940000744.5512064 qam
24619999144.5512064 qam
35370000744.5512064 qam
46030003446512064 qam
ChannelChannel TypeT1 TimeoutsT2 TimeoutsT3 Timeouts
1ATDMA000
2ATDMA000
3ATDMA000
4ATDMA000
ChannelFrequency (Hz)Power (dBmV)SNR (dB)Modulation
1411000000-637256 qam
2203000000-237256 qam
3211000000-2.237256 qam
4219000000-2.437256 qam
5227000000-2.937256 qam
6235000000-3.437256 qam
7243000000-437256 qam
8251000000-4.536256 qam
9259000000-536256 qam
10267000000-537256 qam
11275000000-537256 qam
12283000000-537256 qam
13291000000-4.937256 qam
14299000000-4.537256 qam
15307000000-4.537256 qam
16315000000-4.237256 qam
17323000000-4.237256 qam
18363000000-4.737256 qam
19371000000-4.537256 qam
20379000000-4.537256 qam
21387000000-4.737256 qam
22395000000-5.237256 qam
23403000000-5.737256 qam
24419000000-637256 qam
1Locked37.600
2Locked37.360
3Locked37.350
4Locked37.6160
5Locked37.660
6Locked37.350
7Locked37.300
8Locked36.660
9Locked36.600
10Locked37.350
11Locked37.330
12Locked37.360
13Locked37.3120
14Locked37.320
15Locked37.360
16Locked37.650
17Locked37.300
18Locked37.660
19Locked37.350
20Locked37.650
21Locked37.6120
22Locked37.360
23Locked37.300
24Locked37.350
  • 25.12K
  • 1.44K
  • 3.2K
Message 9 of 15
Are you sure the attenuator has been removed? Your levels are still reading the same and I would have expected them to have increased.
  • 9
Message 10 of 15
The attenuator has been completely removed - it was on a small cable approx 30cm in length and had an in-line cylinder. I've now attached the cable - without the attenuator directly into the back of the modem.
The difference is tiny - less 10% when I ran the figures thro excel (-113 vs -105) in total and average has moved from -4.7 to -4.4
Any ideas of anything else I can try ?
