Broadband intermittent and TV pixelating
dgmackenzie_uk
changed package the other day and day after WiFi keeps dropping out and TV pixelates. Have noticed plug on wall with co-ax going in has a green led that seems to fluctuate a tie in with pixelation.
Support recommend a pin reset of hub 3. Which made no difference. Any ideas what else I could try?
Have attached photo of the plug with co-ax and  flashing green led.
3 REPLIES 3
dgmackenzie_uk
WiFi has improved but TV signal still dreadful. I'm sure it is something to with the plug that the co-ax goes into. When the green led flicks off it often coincides with a pixelation.
TV is unwatchable.
That plug provides power to the wall box on the outside of your home, that contains a device that converts the fibre to coax:
If it's faulty it would cause a loss of services.
Hi Dgmackenzie_uk,
Thanks for using the Community Forums to get this issue with your services looked into, I am sorry if this has been causing some frustration 😥
I understand you've made a recent change to your services, this could be the reason for the issues as service could become a little intermittent whilst a package change is handled behind the scenes.
I have already taken the time to check your Hub & TV boxes for any outstanding issues, but everything seems to be working fine on my side.
Could you let us know how things are now since you last posted please?
Megan_L
