  • 14
Message 1 of 15
Broadband dropouts
As with many of you, I have been suffering multiple dropouts over a long period of time. Many of the tips on here, deep resets, separate ASUS router, etc give a temporary improvement but it never lasts. The help desk has been disgraceful. Today I was told that there's been an area fault since the beginning of April that won't be fixed until 19th of Aug. Even if I believed it I would consider it unacceptable but sadly I've heard it all before.
Is there a solution other than changing providers? As I came to Virgin due to the BT/Yahoo fiasco what other options exist?
For info, probs exist wifi or wired,
Cheers
Phil
  • 7.01K
  • 517
  • 907
Legend
Message 2 of 15
Re: Broadband dropouts
It can be difficult diagnosing problems without some basic information.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with …
Can you set up a Broadband Quality Monitor (BQM) at thinkbroadband.com - this will give you an insight into what is happening with the signal at the other side of the Hub, it will take a few hours to get any kind of trend showing although you can post the link straight away.
 In the URL box paste the link you copied and then click OK - you can post the link straight away.
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 14
Message 3 of 15
Mike,
Thanks for the quick (immediate!) response. I have been running the BQM but with the switching between Virgin and ASUS as the router I'll give it 24hrs on Virgin only before posting. The service check shows OK as usual, running the test has occasionally flagged that something might be intermittent but maybe not at my end,
Cheers
Phil
  • 15.74K
  • 1.65K
  • 2.69K
Message 4 of 15
As Mike asked - post the Hub stats... here is how...
In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) and hit return. On the first page up [there should be no need to login if you have done so before] click on the “router status” icon at top right (SH2’s) or text at bottom-middle of first page up (Hub3) and then copy/paste as “Formatted Text” (not images) 3 FULL sets of data onto here – from the Downstream, Upstream, & Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button a second time).
  • 14
Message 5 of 15
Let's try! I think this is what you were looking for Mike/John
NOTE. Spitting and reposting due to size restrictions
31/07/2020 14:54:36Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 14:38:47noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 13:11:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 13:10:51criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 13:10:45criticalREG RSP not received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 13:10:45ErrorT6 Timeout and retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 13:10:45criticalRegistration RSP rejected unspecified reason;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 13:10:45criticalRegistration RSP rejected message syntax error;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 13:10:20criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 13:09:34criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 11:23:19criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 11:22:49criticalREG RSP not received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 11:22:49ErrorT6 Timeout and retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 11:22:49criticalRegistration RSP rejected unspecified reason;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 11:22:49criticalRegistration RSP rejected message syntax error;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 11:22:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 11:22:0criticalREG RSP not received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 11:22:0ErrorT6 Timeout and retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 11:22:0criticalRegistration RSP rejected unspecified reason;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 11:22:0criticalRegistration RSP rejected message syntax error;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
 0
0
  • 14
Message 6 of 15
2nd set
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
1326000005.1512064 qam9
2394000005.1512064 qam4
3462000005.1512064 qam3
4537000005.1512064 qam2
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
1330750000-5.238256 qam25
2250750000-4.538256 qam15
3258750000-4.438256 qam16
4266750000-4.738256 qam17
5274750000-4.938256 qam18
6282750000-4.938256 qam19
7290750000-4.938256 qam20
8298750000-4.738256 qam21
9306750000-538256 qam22
10314750000-5.238256 qam23
11322750000-5.238256 qam24
12378750000-6.238256 qam26
13386750000-6.238256 qam27
14394750000-6.238256 qam28
15402750000-6.438256 qam29
16410750000-6.438256 qam30
17418750000-6.238256 qam31
18426750000-5.738256 qam32
19434750000-5.938256 qam33
20442750000-6.238256 qam34
21450750000-6.538256 qam35
22458750000-6.538256 qam36
23466750000-6.738256 qam37
24474750000-6.938256 qam38
1Locked38.9150
2Locked38.9130
3Locked38.9140
4Locked38.9190
5Locked38.6150
6Locked38.9120
7Locked38.9130
8Locked38.9110
9Locked38.9260
10Locked38.9300
11Locked38.6150
12Locked38.9200
13Locked38.9170
14Locked38.6240
15Locked38.6210
16Locked38.9200
17Locked38.9180
18Locked38.9180
19Locked38.9170
20Locked38.9240
21Locked38.6210
22Locked38.9180
23Locked38.6130
24Locked38.625
  • 15.74K
  • 1.65K
  • 2.69K
Message 7 of 15
Looks like you have power issues both up and down.
The 4 Up's are all at the top of their recommended range and all your down ones are low and about 1/2 are below the recommended minimum of -6 dBmV.
It will need a VM person to take a look and probably a VM tech visit to adjust the power levels. Either/and try calling in or wait until a VM person spots this thread and offers help. That can take a few days.
  • 14
Message 8 of 15
John and Mike,
Thanks for the help. I can't face that helpdesk again as I get violent urges and losing my temper with some poor minimum wages sod is unfair! Maybe it is really due to the claimed local issues. Will wait for a VM tech on here,
Thanks again
Phil
  • 7.01K
  • 517
  • 907
Legend
Message 9 of 15
You can wait on here for one of the VM Staff to pick up the thread but this may take a few days.
DO NOT bump your post, it doesn't help.
Mike Robinson
  • 3.85K
  • 178
  • 301
Message 10 of 15
Hi philjk,
Thanks for your post on our Community Forums and I'm sorry to see you've been experiencing broadband issues.
What I would advise is, that I've been able to look at the services in your local area and can see that we're currently struggling with high utilisation in the area.
As a result, we will need to allow the high utilisation issue to pass before we can do further work on diagnosing any issues you may have with the connection.
I've included the high utilisation notes below for you
Kindest regards,
David_Bn
Description:high utilisation site 22 watf-cmts-11-logical-cable-upstream3/2/1.0 - Status report || You might find that your Virgin Fibre, Virgin TV or TiVo® services are intermittent, with the picture freezing or disappearing now and then. We are sorry and any inconvenience caused.
Remedy Number:F007921155
Status:Our engineer is on site and they're working to fix the problem
Date Open:01 APR 2020 09:14
Estimated end date:19 AUG 2020 09:00
We are planning to undertake some upgrades to support the increased demand for our services in your area. When completed, any slow broadband speeds and buffering on TiVo apps you may be experiencing (particularly at peak times) will be resolved.
